Turbo?
Jun 29, 2016 5:12:32 GMT -5
Post by 180°off on Jun 29, 2016 5:12:32 GMT -5
Anybody have first hand or maybe even 2nd hand experience with this turbo or one like it? Is it worth it? IHI RHB31 3T-505 Worlds Smallest Turbocharger
Post by arkie on Jun 29, 2016 8:18:42 GMT -5
I have seen it before. No experience with it though. I have read that a major problem in trying to get a turbo to work on a scoot is the exhaust flow or lack thereof. By no means am I an expert in this or any other turbo. Just passing on what little I know.
Turbo?
Jun 29, 2016 8:20:36 GMT -5
Post by wutno on Jun 29, 2016 8:20:36 GMT -5
I wonder if you could just use passing air to spool the turbo if exhaust flow isn't enough. ヽ(´ー`)ノ
Turbo?
Jun 29, 2016 8:22:15 GMT -5
Post by arkie on Jun 29, 2016 8:22:15 GMT -5
I wonder if you could just use passing air to spool the turbo if exhaust flow isn't enough. ヽ(´ー`)ノ Ummmm No.
Turbo?
Jun 29, 2016 8:31:00 GMT -5
Post by wutno on Jun 29, 2016 8:31:00 GMT -5
I literally know nothing about turbos so I'm only saying this because I'm tired and can't see any reason this wouldn't work but, get a big ol' cone and funnel the air right into the turbo, can even put it on the front of the scoot to get maximum airflow
Turbo?
Jun 29, 2016 9:13:04 GMT -5
via mobile
Post by Chris Cristini on Jun 29, 2016 9:13:04 GMT -5
I could see if you EFI it would work well however a little 4 stroke will loose a lot of response and get tons of turbo lag I would imagine the turdo kicking in at the wrong time like on sand lol also a lower compression ratio is advised to reduce pre detonation AKA knock.
Turbo?
Jun 29, 2016 9:21:16 GMT -5
via mobile
Post by iwiketuddlz on Jun 29, 2016 9:21:16 GMT -5
That there is one expensive a** turbo I'm sure of it
Turbo?
Jun 29, 2016 9:40:22 GMT -5
Post by arkie on Jun 29, 2016 9:40:22 GMT -5
That there is one expensive a** turbo I'm sure of it The knock off model is $300 the real deal well its a bargain I'm sure at $1000
Turbo?
Jun 29, 2016 11:07:46 GMT -5
via mobile
Post by Chris Cristini on Jun 29, 2016 11:07:46 GMT -5
Yes the price is stupid even for the knock off that should be a $200 turbo for the real one I could see a complete small engine kit with EFI conversion for like $750. If I had the ability to cast I'd make one lol
Post by Deleted on Jun 29, 2016 13:32:11 GMT -5
I literally know nothing about turbos so I'm only saying this because I'm tired and can't see any reason this wouldn't work but, get a big ol' cone and funnel the air right into the turbo, can even put it on the front of the scoot to get maximum airflow To get any decent boost from that small turbo, it would have to be spinning at least 100,000 rpm. Ram air from riding 30 mph just ain't gonna cut it. My guess is that it would not even be enough to turn it 1 rpm. Don't forget, there is a compressor on the other end of that shaft so there will be increasing resistance to turning the faster it goes.
Bill
Post by Lucass2T on Jun 29, 2016 16:28:05 GMT -5
no
Turbo?
Jun 30, 2016 13:29:53 GMT -5
via mobile
Post by just1artist on Jun 30, 2016 13:29:53 GMT -5
Why turbo? Why not electric "supercharger"? No "draw" off motor and no lag... Have made a few... The cbrr motor on my shadow adds 4-6 lbs boost almost on demand... Flip switch, load up and gone...
I really don't like turbos anyway lol
Turbo?
Jun 30, 2016 14:45:04 GMT -5
Post by Chris Cristini on Jun 30, 2016 14:45:04 GMT -5
Ah thermal dynamics say that's impossible!! Lol the energy needed to boost is far beyond what are electrical systems can handle I have years of experience just to discover its against physics like perpetual motion. Here is my Super charger build from years ago read comments.
Post by Deleted on Jun 30, 2016 15:32:29 GMT -5
I agree. I have seen several vids on Youtube with dyno testing showing that gains from the electric supercharger are a myth...at least the ones they were testing. I have no idea if they are all similar or not but I do know that you do not get something for nothing. If you had a powerful enough generator to really run one that might give some boost, the drag from the generator would more that use up any possible gains from the electric supercharger.
Bill
Turbo?
Jun 30, 2016 18:45:11 GMT -5
via mobile
Post by ryan_ott on Jun 30, 2016 18:45:11 GMT -5
Do I really want to get involved in this debate not really. But may years ago (10-12) I built an electric supercharger/ turbo from the compressor wheel of a turbo attached to an electric rc car motor(7.2v) and ran it off of 12 volts it did make 2-3 psi but could not run long before the brushes overheated. Is it possible yes with the right motor.
