PCDI
Jul 20, 2016 10:06:22 GMT -5
Post by iwannascoot on Jul 20, 2016 10:06:22 GMT -5
If you're going to make an AC DC CDI it should be called "Ride On." Perhaps Thunder Struck, Dirty Deeds Done Dirt Cheap, Live Wire...
Billy
PCDI
Jul 20, 2016 11:03:07 GMT -5
Post by Chris Cristini on Jul 20, 2016 11:03:07 GMT -5
Thunder struck CDI hmm sound interesting
Post by Deleted on Jul 20, 2016 11:06:52 GMT -5
Thunder struck CDI hmm sound interesting I like it. A black case with a yellow lightning bolt decal on it.
Bill
PCDI
Jul 20, 2016 16:24:55 GMT -5
spaz12 likes this
Post by Chris Cristini on Jul 20, 2016 16:24:55 GMT -5
Post by jareeb on Jul 20, 2016 16:51:27 GMT -5
gladly be a beta tester as i need a cdi. i have the kheper cdi and it doesnt work on a mina stator. kheper-scooter.com
Post by moofus02 on Jul 20, 2016 17:42:32 GMT -5
This is getting good
Post by 190mech on Jul 20, 2016 18:19:56 GMT -5
I machined a spindle that fit the Mina cases and cut a large flywheel taper on one end,was built to test different ignition setups on the bench,have a vacuum cleaner motor(read very high RPM's)to turn it with variable speeds,that way a graph can be drawn...Be glad to ship it to you,or do field tests if needed..
Post by Chris Cristini on Jul 20, 2016 18:51:57 GMT -5
Thank you John Maybe in a little bit however now I want to build something like that I have a bunch of motors laying around thats a Freaking awesome Idea the wife doesn't want exhaust in the house.
Post by jareeb on Jul 20, 2016 19:37:59 GMT -5
i have a large taper flywheel hub. and a complete large taper flywheel that i started to lighting. id donate to the project. let me know if you need it!
Post by moofus02 on Jul 20, 2016 19:38:16 GMT -5
I machined a spindle that fit the Mina cases and cut a large flywheel taper on one end,was built to test different ignition setups on the bench,have a vacuum cleaner motor(read very high RPM's)to turn it with variable speeds,that way a graph can be drawn...Be glad to ship it to you,or do field tests if needed.. Hey John did you ever test the mina flywheel to failure? Just curious how high you could turn one or how fast you tested them to.
Post by 190mech on Jul 20, 2016 19:46:12 GMT -5
PCDI
Jul 20, 2016 19:50:58 GMT -5
via mobile
190mech likes this
Post by Chris Cristini on Jul 20, 2016 19:50:58 GMT -5
I machined a spindle that fit the Mina cases and cut a large flywheel taper on one end,was built to test different ignition setups on the bench,have a vacuum cleaner motor(read very high RPM's)to turn it with variable speeds,that way a graph can be drawn...Be glad to ship it to you,or do field tests if needed.. Your definitely on the list for a free beta my friend!!! After all I would not have started building a CDI if it wasn't for you I used to think the Stock CDI was Good enough now I see potential and I want this and every other project to be as affordable as possible when they come together I hate seeing all of these performance parts for an arm and a leg when they hardly improve anything.
PCDI
Jul 20, 2016 19:52:25 GMT -5
via mobile
Post by Chris Cristini on Jul 20, 2016 19:52:25 GMT -5
i have a large taper flywheel hub. and a complete large taper flywheel that i started to lighting. id donate to the project. let me know if you need it! Sorry I am still learning about the different flywheels out there what is a large taper for?
Post by Deleted on Jul 20, 2016 20:01:09 GMT -5
I machined a spindle that fit the Mina cases and cut a large flywheel taper on one end,was built to test different ignition setups on the bench,have a vacuum cleaner motor(read very high RPM's)to turn it with variable speeds,that way a graph can be drawn...Be glad to ship it to you,or do field tests if needed.. Your definitely on the list for a free beta my friend!!! After all I would not have started building a CDI if it wasn't for you I used to think the Stock CDI was Good enough now I see potential and I want this and every other project to be as affordable as possible when they come together I hate seeing all of these performance parts for an arm and a leg when they hardly improve anything. Or , they make things worse! A lot of those Orange "high performance" spark coils have not even worked at all from what I have read. Or, if they do work, it is just a very weak spark. I wish you a lot of luck on this endeavor. It appears that it should be straightforward electronics engineering, and it might be. It makes me wonder why no one has done this for real already? I think this is going to be great. Bill
Post by 90GTVert on Jul 20, 2016 20:06:31 GMT -5
Sorry I am still learning about the different flywheels out there what is a large taper for? Usually a 12mm piston pin crank will have a large taper. The 90cc stuff is typically large taper.
