Post by floyd2133 on Aug 18, 2016 11:44:30 GMT -5
I striped my kick lever so i bought another one. I'm having trouble screwing my screw into the lever any pro opinion?
Post by 90GTVert on Aug 18, 2016 12:10:41 GMT -5
Is the bolt damaged/stripped? Threads in the new lever look OK?
Post by floyd2133 on Aug 18, 2016 17:03:22 GMT -5
I bought a new bolt tried to use old lever Didn't work
Post by floyd2133 on Aug 18, 2016 17:04:19 GMT -5
Then bought a new lever screw would not go in when lever is flushed but will go in when it is half way it worked for a min now it's stripping
Post by floyd2133 on Aug 18, 2016 17:05:08 GMT -5
I'm bout to jbweld it and jus buy a new case n gears n lever smh ugh
Post by floyd2133 on Aug 18, 2016 17:05:36 GMT -5
Has anybody used jbweld ok kick lever b4?
Post by floyd2133 on Aug 18, 2016 17:50:59 GMT -5
Post by Deleted on Aug 18, 2016 17:53:14 GMT -5
Has anybody used jbweld ok kick lever b4? It is not strong enough for the pressure that will be put on it when kicking. That's a lot of leverage (force multiplication) there. Bill
Post by nelson on Aug 18, 2016 21:40:14 GMT -5
UsuAlly i stick a flat head in to open it a bit as i push ot on. Once it is on take out flat head make sure kicker holes line up of not get some big pump pliers give a squish as yoi try to get the screw in straight. Jb weld gonna leave you stuck somewhere!
Post by jstich on Aug 18, 2016 23:34:05 GMT -5
I guess I need to be the guy that reminds the OP of the kickstart is only for emergencies or the cvt cover will break.
Post by Deleted on Aug 19, 2016 9:40:39 GMT -5
I guess I need to be the guy that reminds the OP of the kickstart is only for emergencies or the cvt cover will break. I use my kick start about 90% of the time to start my scoot. (I am trying to preserve my battery as long as possible, ha ha) So far, for 2 years, so good. I think if the kick lever is adjusted properly...in the correct position, and you don't stomp on it when it is at the bottom of the swing, it will be fine. Just my opinion based on my own experience. Bill PS Keeping your scoot in good tune with properly adjusted valves, good plug, etc. makes a big difference. I have seen folks kicking their scoots like 15 times each time they start it...I can usually get away with a single kick...sometimes two.
Post by floyd2133 on Aug 19, 2016 11:57:07 GMT -5
Yes that didn't work but I have heard kicking it to many times can mess up case
Post by floyd2133 on Aug 19, 2016 11:59:36 GMT -5
However my push starter is so unreliable. I have to keep it on trickle charge wen I park it and I pray it works when o try to crank it I have to hold it down for bout 5 secs about 5 times till it starts. I have a 12 bolt battery.
Post by nelson on Aug 19, 2016 16:12:42 GMT -5
I have used my kicker for 2 years. When you use the mhr overrange cvt you have to remove the starter clutch off the crank actually the boss it rides on. I have yet to break my cvt cover. Starts first kick when i pull choke, i dont even have a battery!
Post by niz76 on Aug 19, 2016 20:33:33 GMT -5
Same here. No e-start due to upgraded CVT components. If it doesn't start on first kick I wonder what's up!
