Post by floyd2133 on Sept 17, 2016 7:08:20 GMT -5
Kick start not working it sounds like stripping but it's not . It is dmsomething inside like the lil pulley pushing out on crank gears isn't connecting so wheel can turn Video here youtu.be/TZaci2rXGF8
Post by humanshield on Sept 17, 2016 9:49:21 GMT -5
Take the CVT cover off. You should easily see what's wrong. Post a few hi res pics of the parts and I can tell you exactly whats wrong.
Possibly just the spring popped off but could be something else.
Post by floyd2133 on Sept 17, 2016 11:03:02 GMT -5
Post by floyd2133 on Sept 17, 2016 13:36:45 GMT -5
Post by Cincikid on Sept 17, 2016 17:11:47 GMT -5
Are you missing any bolts on the cvt cover? When you press the kick wile the cover is off the movement looks right?
Post by gsx600racer on Sept 17, 2016 17:41:34 GMT -5
You need to have All the bolts in the CVT cover, your vid shows all the bolts on the top of the cover out. Cincikid, Good eye. I didn't see that at first.
Post by floyd2133 on Sept 17, 2016 19:57:16 GMT -5
Oh ok
Post by stoneforth on Sept 17, 2016 20:28:07 GMT -5
Post by Deleted on Sept 17, 2016 20:58:43 GMT -5
Bill
Post by gsx600racer on Sept 17, 2016 21:01:40 GMT -5
Bill That better be kettle corn.
Post by floyd2133 on Sept 17, 2016 22:45:23 GMT -5
Y'all not funny
Post by floyd2133 on Sept 25, 2016 13:17:53 GMT -5
My mechanic says it's the part that pushes out that catches the starter gear is messed up that's why. Here is a pic of my finger pointing to the part it's the black piece behind the nut on the variator fan
a63.tinypic.com/2ponkvm.jpg
a68.tinypic.com/206lcoz.jpg
Post by gsx600racer on Sept 25, 2016 14:06:41 GMT -5
The part you are referring to is called the "kick ratchet gear". What I don't understand, when you had someone work in it the last time, they replaced the drive face fan(the white part in picture) why did they not replace the ratchet gear too. I hope the person that replaced the fan is not the same person that's telling you your ratchet gear is bad too.
Post by Deleted on Sept 25, 2016 14:10:13 GMT -5
I want to be a scoot mechanic where Floyd lives. Evidently, I could make a fortune ripping people off. Actually, I do not care enough about money to rip anyone off...but...man...there is a real pattern here. Bill www.ebay.com/itm/like/121940118425?lpid=82&chn=ps&ul_noapp=trueHere you go...$5.69 and free shipping. I have no idea why, at this low of a cost, it was not replaced when the fan was repaired?
Post by floyd2133 on Sept 25, 2016 16:01:18 GMT -5
His dumb ass didn't know what it was called I payed a different mechanic to put the belt n variator on . Cause I couldn't get the nut off even with the variator lock
