Post by floyd2133 on Nov 12, 2016 23:40:44 GMT -5
The kill switch works so the ignition switch should too ....? I understand that the lights don't come on until it is running however why can't I ignition switch start it? I have ordered these parts coming in Friday maybe the new ignition switch n turn signal n brake levers should fix my problem Also this is a pic of my wire set up
Post by floyd2133 on Nov 12, 2016 23:41:46 GMT -5
The kill switch works so the ignition switch should too ....? If its wired correctly, the key should turn off the scooter as well as the kill switch. The key turns off the scooter fine as well as the kill switch. My question is the ignition switch that is not working
Post by gsx600racer on Nov 12, 2016 23:58:48 GMT -5
If i remember correctly, the brake lever was broken. If that's the case, chances are that the brake switch is not being triggered. If that's the case, the start button will not work. The brake switch is tied to the start circuit. I think I mentioned that in a previous post.
Post by floyd2133 on Nov 12, 2016 23:58:48 GMT -5
The kill switch works so the ignition switch should too ....? I understand that the lights don't come on until it is running however why can't I ignition switch start it? I have ordered these parts coming in Friday maybe the new ignition switch n turn signal n brake levers should fix my problem Also this is a pic of my wire set up Red is turn signal Blue idk?
Post by floyd2133 on Nov 13, 2016 0:01:46 GMT -5
If i remember correctly, the brake lever was broken. If that's the case, chances are that the brake switch is not being triggered. If that's the case, the start button will not work. The brake switch is tied to the start circuit. I think I mentioned that in a previous post. I have tried to test the brake here is a video vimeo.com/191325858
Post by floyd2133 on Nov 13, 2016 0:06:11 GMT -5
This is the ignition switch set up One wire has no where to go
Post by gsx600racer on Nov 13, 2016 0:08:45 GMT -5
I understand that the lights don't come on until it is running however why can't I ignition switch start it? I have ordered these parts coming in Friday maybe the new ignition switch n turn signal n brake levers should fix my problem Also this is a pic of my wire set up Red is turn signal Blue idk? The part you have circled in blue, there are usually 2 of those double connectors. The wires from the brake switches are connected to them. One wire from each brake switch.
Post by floyd2133 on Nov 13, 2016 0:09:13 GMT -5
Ok I connected my 5 wire into the 4 wire prong but I'm still not getting anything also one green wire is sticking out . How do I check for connectivity what should I do with extra wire Use your multi-meter to check for continuity(set to ohms) What will this do ? Tell me witch green wire to use? If that's the case I can just swap them out n see witch one works . But I don't think that's it???
Post by gsx600racer on Nov 13, 2016 0:09:46 GMT -5
Pull the black boot off the back of the key switch and take a pic of the back of the switch.
Post by floyd2133 on Nov 13, 2016 0:10:18 GMT -5
Red is turn signal Blue idk? The part you have circled in blue, there are usually 2 of those double connectors. The wires from the brake switches are connected to them. One wire from each brake switch. So I need to trace the brake switch wire n run it to there?
Post by floyd2133 on Nov 13, 2016 0:11:36 GMT -5
Post by floyd2133 on Nov 13, 2016 0:14:09 GMT -5
Post by floyd2133 on Nov 13, 2016 0:15:41 GMT -5
So I need to trace the brake switch wire n run it to there? Red turn signal Blue idk Yellow brake levers
Post by gsx600racer on Nov 13, 2016 0:17:55 GMT -5
Your brake wiring is here and connected. I do not know what the other plugs are for.
Post by floyd2133 on Nov 13, 2016 0:19:38 GMT -5
Your brake wiring is here and connected. I do not know what the other plugs are for. I described it in the first previous post hopefully when my new levers come in it will work??
