Post by floyd2133 on Nov 12, 2016 19:58:19 GMT -5
I bought the wrong ignition system . The original has 4 prongs this one has 5 is there anyway I can wire this up to make it work with out sending it back vimeo.com/191313862
Post by floyd2133 on Nov 12, 2016 20:26:05 GMT -5
Post by gsx600racer on Nov 12, 2016 21:40:41 GMT -5
I would swap the pins from one connector to the other(matching the same color wire to pin location). Just check continuity between the 2 green wires.(I am assuming they are both grounds and go to the same place on the back of the key switch) On the plug, the pins are held in with a small tab.(circled in green) Us a small screwdriver bend the small tab back in, and the pin will slide out.(circled in green) Once the pin out you will need to bend the tab on the pin back out thickness of the screwdriver tip.(circled in green)
Tab Highlighted in green
Screwdriver used to bend tab back out. To get it started, push it out from the opposite side.
This is what the tab should look like when bent back out.
The pins only go in the connector ONE way. Do one pin at a time, it will be easier than trying to remember which wire went where.
Post by floyd2133 on Nov 12, 2016 21:50:39 GMT -5
Ok I connected my 5 wire into the 4 wire prong but I'm still not getting anything also one green wire is sticking out . How do I check for connectivity what should I do with extra wire
Post by floyd2133 on Nov 12, 2016 22:00:31 GMT -5
Post by floyd2133 on Nov 12, 2016 22:02:16 GMT -5
However it works when bridge to solenoid but key has to be turned for it to work . So I'm guessing I have it hooked up right because I can read the rpm on the dash however brake light isn't working and push start isn't working only works from solenoid bridge
Post by floyd2133 on Nov 12, 2016 22:29:24 GMT -5
Also dash lights only come on when started shouldn't they come on when key is turned
Post by floyd2133 on Nov 12, 2016 22:31:16 GMT -5
Post by gsx600racer on Nov 12, 2016 22:58:49 GMT -5
Also dash lights only come on when started shouldn't they come on when key is turned The head lights only come on when the engine is running.
Post by gsx600racer on Nov 12, 2016 23:01:31 GMT -5
Ok I connected my 5 wire into the 4 wire prong but I'm still not getting anything also one green wire is sticking out . How do I check for connectivity what should I do with extra wire Use your multi-meter to check for continuity(set to ohms)
Post by gsx600racer on Nov 12, 2016 23:03:43 GMT -5
However it works when bridge to solenoid but key has to be turned for it to work . So I'm guessing I have it hooked up right because I can read the rpm on the dash however brake light isn't working and push start isn't working only works from solenoid bridge Are you holding the brake lever when you are trying to start with the button ? Have you checked the fuses to see if they ok ?(check with multi-meter set to ohms) The rear brake light should come on if the key is on and the brake lever is applied.
Post by floyd2133 on Nov 12, 2016 23:04:21 GMT -5
Also dash lights only come on when started shouldn't they come on when key is turned The head lights only come on when the engine is running. I'm saying the dash lights should come on when the key is turned just like this one vimeo.com/191323520
Post by floyd2133 on Nov 12, 2016 23:05:24 GMT -5
However it works when bridge to solenoid but key has to be turned for it to work . So I'm guessing I have it hooked up right because I can read the rpm on the dash however brake light isn't working and push start isn't working only works from solenoid bridge Are you holding the brake lever when you are trying to start with the button ? Have you checked the fuses to see if they work ? The rear brake light should come on if the key is on and the brake lever is applied. It works from a kick start or solenoid jump but not the ignition button yes I'm holding down the brake
Post by floyd2133 on Nov 12, 2016 23:05:47 GMT -5
The kill switch works so the ignition switch should too ....?
Post by gsx600racer on Nov 12, 2016 23:37:47 GMT -5
The kill switch works so the ignition switch should too ....? If its wired correctly, the key should turn off the scooter as well as the kill switch.
