Post by gsx600racer on Nov 13, 2016 0:20:08 GMT -5
Pull the black boot off the back of the key switch and take a pic of the back of the switch. Try swapping with the other green wire. Green=ground From the looks of the pic, there are 2 separate ground connections on the key switch.
Post by floyd2133 on Nov 13, 2016 0:21:05 GMT -5
Try swapping with the other green wire. Green=ground From the looks of the pic, there are 2 separate ground connections on the key switch. I will try swapping
Post by gsx600racer on Nov 13, 2016 0:21:46 GMT -5
Sorry, without it in front of me, it take some time for my brain to see the big picture.
Post by floyd2133 on Nov 13, 2016 0:27:30 GMT -5
Sorry, without it in front of me, it take some time for my brain to see the big picture. I tried to swap still same effect I will try to meddle with it until I get it working
Post by gsx600racer on Nov 13, 2016 0:30:16 GMT -5
Does the rear brake light come on when you squeeze the front brake lever(right side or the side with the stater button) ? With the key on.
Post by floyd2133 on Nov 13, 2016 0:31:21 GMT -5
Does the rear brake light come on when you squeeze the front brake lever(right side or the side with the stater button) ? Naw it doesn't even come on when started I haven't check the bulb tho
Post by gsx600racer on Nov 13, 2016 0:34:09 GMT -5
That might be part of the problem. If the bulb is good then there is a issue with that circuit. Id check the bulb, and check the fuses by the battery. If you get the bulb to light up, then the fuse is good. You need power from that circuit(brake) to make the start circuit to work. You might have to re-swap the green too.
Post by floyd2133 on Nov 13, 2016 0:35:21 GMT -5
That might be part of the problem. If the bulb is good then there is a issue with that circuit. Id check the bulb, and check the fuses by the battery. Fuse is Goodi will check bulb
Post by floyd2133 on Nov 13, 2016 8:30:49 GMT -5
That might be part of the problem. If the bulb is good then there is a issue with that circuit. Id check the bulb, and check the fuses by the battery. If you get the bulb to light up, then the fuse is good. You need power from that circuit(brake) to make the start circuit to work. You might have to re-swap the green too. I switched bulbs n when I cranked by solenoid it came on turning the key n pushing the ignition switch does nothing Video here vimeo.com/191348069
Post by floyd2133 on Nov 13, 2016 11:30:40 GMT -5
UPDATE I wired the existing start switch to my working moped and it works so the switch isn't the issue Video vimeo.com/191359098
Post by floyd2133 on Nov 13, 2016 12:03:34 GMT -5
That might be part of the problem. If the bulb is good then there is a issue with that circuit. Id check the bulb, and check the fuses by the battery. If you get the bulb to light up, then the fuse is good. You need power from that circuit(brake) to make the start circuit to work. You might have to re-swap the green too. Hey buddy it was the fuse I never listen thanks for the late night help bro we are in Buisness Video vimeo.com/191362871
Post by gsx600racer on Nov 13, 2016 19:13:59 GMT -5
Cool.
Post by floyd2133 on Nov 13, 2016 19:15:10 GMT -5
Cool. Check out my lab bro
