Post by gsx600racer on Dec 3, 2016 19:53:21 GMT -5
I seen that one just didn't want to spend money on zip ties Floyd, come on man. Those zip ties cost all of maybe $1. Probably less. Bill A rim and tire is so much cheaper than a bag of zip ties... smh
Post by floyd2133 on Dec 3, 2016 21:07:51 GMT -5
Floyd, come on man. Those zip ties cost all of maybe $1. Probably less. Bill A rim and tire is so much cheaper than a bag of zip ties... smh Well when you put it like that maybe not .
Post by sparklepants on Dec 4, 2016 7:50:54 GMT -5
Yea, at our local store one can get a huge bag of zip ties for around $5. I bet tractor supply company has them too.
Post by Kasperthelost on Dec 6, 2016 10:26:52 GMT -5
Just a suggestion have you tried the soapy water mentioned above?
Post by Deleted on Dec 6, 2016 10:38:27 GMT -5
Just a suggestion have you tried the soapy water mentioned above? It's too late. He needs a new wheel and tire now. Bill
Post by floyd2133 on Dec 8, 2016 16:28:20 GMT -5
Just a suggestion have you tried the soapy water mentioned above? It's too late. He needs a new wheel and tire now. Bill What do you think of this rim and tire set Last rim didn't fit hole were ridges are at were to big... Tire 35 Rim 45
Post by 90GTVert on Dec 9, 2016 15:03:38 GMT -5
The tire you are considering is a tube type. Why not get a tubeless? You can find Kenda K329 for that or less usually. If you're having a real tough time with the install, it's worth just paying a tire shop $10-20 IMO. Cheaper than buying another tire or tube or wheel or whatever.
Post by floyd2133 on Dec 9, 2016 16:34:58 GMT -5
The tire you are considering is a tube type. Why not get a tubeless? You can find Kenda K329 for that or less usually. If you're having a real tough time with the install, it's worth just paying a tire shop $10-20 IMO. Cheaper than buying another tire or tube or wheel or whatever. I have messed up rim n tire I'm confident I can install tire however thanks for pointing that out Ima make sure it's tubless What about this one?
Post by gsx600racer on Dec 9, 2016 17:01:02 GMT -5
It's too late. He needs a new wheel and tire now. Bill What do you think of this rim and tire set Last rim didn't fit hole were ridges are at were to big... Tire 35 Rim 45 You show a 13" rim and a 10" tire. If you thought you had problems before getting the tire on the rim, it will be impossible making that 10" tire fit a 13" rim. The tire size has to match the rim size.
Post by floyd2133 on Dec 9, 2016 17:02:52 GMT -5
What do you think of this rim and tire set Last rim didn't fit hole were ridges are at were to big... Tire 35 Rim 45 You show a 13" rim and a 10" tire. If you thought you had problems before getting the tire on the rim, it will be impossible making that 10" tire fit a 13" rim. The tire size has to match the rim size. Checkout post above yours
Post by gsx600racer on Dec 9, 2016 22:43:06 GMT -5
This picture you posted before shows the tire being 130/70 - 12. I lighten the picture exposures so its easier to see. Not sure why you are looking at 13" wheels and tires. (unless you are thinking "the bigger the tire the faster you will go")
Post by floyd2133 on Dec 10, 2016 1:51:04 GMT -5
This picture you posted before shows the tire being 130/70 - 12. I lighten the picture exposures so its easier to see. Not sure why you are looking at 13" wheels and tires. (unless you are thinking "the bigger the tire the faster you will go") Oh duh I don't know why I been thinking I need 13 inch rim n tire I need both 12 thanks Ima post up some more pics on my purchase i obviously have the wrong items I the cart I'm such a doe doe bird
Post by floyd2133 on Dec 10, 2016 2:08:17 GMT -5
I think this is the better buy???
Post by jeff84 on Dec 10, 2016 4:00:07 GMT -5
unless you have a rear disk brake, that is not what you want. you need a wheel with a drum the same size drum and spline count as the wheel you have.
Post by floyd2133 on Dec 10, 2016 9:19:25 GMT -5
unless you have a rear disk brake, that is not what you want. you need a wheel with a drum the same size drum and spline count as the wheel you have. What about the Znen tire
