Post by stancejontland on Apr 18, 2017 20:58:26 GMT -5
anyone have a good site for new or replacement pipes? mine is the triangle flange. the pipe to the engine is 2 bolts
Post by 90GTVert on Apr 19, 2017 7:13:11 GMT -5
I don't know of any bolt-on mufflers so it doesn't matter much what the muffler flange is. If you want more than just a sound increase, expansion chamber pipes are the way to go. They will require tuning the CVT (usually lighter rollers and stiffer clutch springs) to get the most out of them. Many don't have to change jetting, but I prefer to go over the carb tune to be safe. The stealth/street pipes may offer mild gains. You also need to choose a pipe that works with what you have for an engine setup. Don't buy the baddest high rev race pipe for a stock or mild engine and don't put a stealth low rev pipe on a race engine. scootertuning.ca/en/1104-exhaust-systems
Post by stancejontland on Apr 19, 2017 11:04:11 GMT -5
I just want the oem replacement really.
Post by 90GTVert on Apr 19, 2017 18:10:24 GMT -5
Oh, sorry. I guess I always have performance stuff on my mind. Just the header section (the pipe) or the muffler or the whole deal? You may try a wanted ad in the classifieds.
Post by stancejontland on Jul 7, 2017 21:56:33 GMT -5
Can you tell me what engine I have? People always tell me but it seems to be argued what it is
Post by AtariGuy on Jul 7, 2017 23:36:45 GMT -5
1E40qmb - you can search yamaha jog/aerox or triton, keeway, lots of others. I believe partsforscooters has a stock replacement - look in street scooters -> exhausts -> 2 stroke. Should be the first one on the list
Post by stancejontland on Jul 8, 2017 19:59:47 GMT -5
So it's not the 139q one
Post by stancejontland on Jul 8, 2017 20:47:35 GMT -5
geo49
Post by geo49 on Jul 9, 2017 20:48:00 GMT -5
Looks like the one on my 2 stroke but internals on the one's for 4 stroke could be different.
Post by AtariGuy on Jul 9, 2017 23:50:09 GMT -5
This should be in 4 stroke troubleshooting then. I'm less help in this area, check with dan50 or dexameth...
Post by dan50 on Jul 10, 2017 0:26:07 GMT -5
Is your engine a 139QMB? That is a 4 stroke. If you have triangle shaped flange, I just bought one off Ebay, American seller. This is the whole exhaust that I bought, but in their store they have the components. I am using this exhaust & muffler on my 47mm BBK, but it will also do good on a stock motor. Link; www.ebay.com/itm/181445829577Again, this is a 4 stroke pipe & muffler for the 139QMB.
Post by dan50 on Jul 10, 2017 0:32:54 GMT -5
Can you post pictures of your engine? Also look for a code stamped on it, usually on the left side. 2 stroke = 1E40QMB ('E' means 2 stroke). 4 stroke = 139QMB (there can be a 'P' on it as in 1P39QMB, same thing).
Post by dexameth on Jul 10, 2017 8:29:55 GMT -5
Most replacement exhausts will come with pipe and header. Make sure to find the right one... The gy6 50 motor or 139qmb has a longer extension and the end that connects to the head. A 150 pipe has a much shorter extension. It will bolt on but the swingarm will be in the way. I've purchased most of mine from eBay. Search 139qmb exhaust and you'll find so many.
Post by dexameth on Jul 10, 2017 8:30:31 GMT -5
I'm speaking 4t here, sorry.
Post by AtariGuy on Jul 12, 2017 20:05:40 GMT -5
