Post by joeorange on Jul 16, 2017 16:25:49 GMT -5
usually its near the ignition coil or on the right side of the frame. youll have to take out the seat bucket to see where it is. once you do its very easy to notice.
Post by stancejontland on Jul 16, 2017 23:58:06 GMT -5
how can i tell what belt i need if all my numbers are rubbed off? i want to replace it b4 vacation in two weeks dont need anything crazy but maybe some more top end speed without changin anything but the belt post ASAP lol
Post by joeorange on Jul 17, 2017 8:19:45 GMT -5
well on way to find out is to get a tape measure and measure to outside diameter of the belt. that would be the easiest way. the other way would be just to order a 788-17-28 belt and hope it works, but in most cases of the 1e40qmb engine that belt would be the one that is likely to work. unless you have the short case engine, but most short case engines have 10" rims. and since yours has 12" rims i strongly suspect that the 788-17-28 belt would work for you.
Post by joeorange on Jul 17, 2017 8:26:43 GMT -5
here is the link where i buy my belts. linkthey are cheap and the shipping is pretty fast in most cases. and since they are cheap i usually buy 2 or 3 at a time so i have spares in case anything happens. the seller also sell most of the important replacement parts, like belts, pistons, cdi's, ignition coils, stators, intakes, roller weights and slider weights. they also sell some mild performance parts. their quality is rather good and they are very reasonably priced. i strongly suggest them.
Post by 90GTVert on Jul 17, 2017 13:59:18 GMT -5
I use 788-17-28 Bando belts on the stock CVT on my long and short case Chinese Minarellis. I won't buy anything but Bando in those, because I've had too many cheap belts break.
Post by stancejontland on Jul 17, 2017 15:48:31 GMT -5
So id be safe getting one of those? Is it a different size or same as stock?
Post by joeorange on Jul 17, 2017 17:05:36 GMT -5
they are a bit longer, which allows for more belt travel. the longer belt allow for a lower takeoff ratio, and a higher top speed ratio. so better take off and a bit more topspeed.
Post by stancejontland on Jul 17, 2017 17:42:57 GMT -5
Cool I'll go ahead and order that one that size. I'll get a bando since 90 knows his stuff. Do you know any other ways to get the variator off without a special tool? I have air tools
Post by joeorange on Jul 17, 2017 17:47:28 GMT -5
just use an impact wrench and the appropiate socket. just be carefull putting it back on with the impact. in somecases the threaded part of the crankshaft can snap off if too much torque is used with the impact.
Post by ryan_ott on Jul 17, 2017 18:06:54 GMT -5
Post by 90GTVert on Jul 18, 2017 6:23:01 GMT -5
The impact is great for removing the vari nut. If you're using it to put it back on, then you should use a torque limiter (torque stick). Something around 30-40 ft-lb.
Post by stancejontland on Jul 22, 2017 2:07:13 GMT -5
Will this work on my scoot? They said its circa 2t
Post by stancejontland on Jul 22, 2017 2:07:39 GMT -5
Post by ThaiGyro on Jul 22, 2017 2:28:46 GMT -5
Post by stancejontland on Jul 22, 2017 3:18:14 GMT -5
