Post by motoxracer98 on Aug 29, 2017 17:25:37 GMT -5
After a week with no word from scooter attack about why my order hadn't shipped out yet i emailed them they replied back telling me my order is 3 weeks behind on back order not to mention ill probably take 2weeks to get here from Germany i dont want to wait that long im having second thoughts anyway about the things ive read about the crank issues. Someone suggested i ask them to check the crank before mailing it to me . I asked them and they refused ..so at this point im thinking of using a different company they have too many issues and it too hard to get anything their website is hard to navigate and i cant even get anyone on the phone. Im going to send am email asking for a refund i paid with paypal hopefully it wont be too hard .
Can anyone tell me what malossi kit and which crank to go with it. The crank is what confuses me is their a crank i can put in that will work with several different kits ? Id like to be at least 86 cc or above . Can someone tell me which kit is right under the Testa Rossa? I would use that if it would last longer and didnt have the odd sized 13mm pin
Post by moofus02 on Aug 29, 2017 17:34:51 GMT -5
Check with niz. He had a mhr kit that used a 44 crank with a 13 or 14 pin. You could use a 12 pin crank that was close with an a piston for the mhr77 to get a 12 pin piston and make it work
Post by motoxracer98 on Aug 29, 2017 23:38:36 GMT -5
How about the airsal racing-xtreme 90cc kit (red cylinder) anyone have any expierence with this and a 45mm crank ?
Post by ryan_ott on Aug 30, 2017 5:40:51 GMT -5
I didn't use the 90 but I ran the 77, 50mm bore. It ran strong.I think top speed was right around 70. That was the first airsal kit I ran but I was pleased with it. It has a vertex piston, single piece head and a odd square exhaust port flange. You may need to file which ever pipe you get to fit correctly. Some prep with oiling holes should help with longevity. I ran it for 6-700 miles then pulled it when I sold the bike. Cylinder and piston still looked pristine.
shoom
Post by shoom on Mar 4, 2019 22:36:42 GMT -5
The airsal 88cc kit (which is the one I presume you are talking about - sometimes advertised as 90cc) is a strong kit over 25hp . But bear in mind, the crankshaft for it uses a piaggio 16mm spline instead of the usual 13 . so you have to use either their variator or the polini evolution 16 for it. But I wouldnt bother using it to tell the truth unless I had at least : decent vforce style reeds, intake, oversize vario/clutch , inner rotor ignition, primary and secondary gearup, decent exhaust like 2fast, reinforced crank bearings etc
Post by repherence2 on Mar 4, 2019 23:34:32 GMT -5
The airsal 88cc kit (which is the one I presume you are talking about - sometimes advertised as 90cc) is a strong kit over 25hp . But bear in mind, the crankshaft for it uses a piaggio 16mm spline instead of the usual 13 . so you have to use either their variator or the polini evolution 16 for it. But I wouldnt bother using it to tell the truth unless I had at least : decent vforce style reeds, intake, oversize vario/clutch , inner rotor ignition, primary and secondary gearup, decent exhaust like 2fast, reinforced crank bearings etc blast from the past Aug 30, 2017 last post
mattyslimz
Post by mattyslimz on Apr 15, 2019 18:53:28 GMT -5
The airsal 88cc kit (which is the one I presume you are talking about - sometimes advertised as 90cc) is a strong kit over 25hp . But bear in mind, the crankshaft for it uses a piaggio 16mm spline instead of the usual 13 . so you have to use either their variator or the polini evolution 16 for it. But I wouldnt bother using it to tell the truth unless I had at least : decent vforce style reeds, intake, oversize vario/clutch , inner rotor ignition, primary and secondary gearup, decent exhaust like 2fast, reinforced crank bearings etc blast from the past Aug 30, 2017 last post Thread bump.. any updates/pics to the hyper set-up Rx 8? I was considering doing the bigger 90cc stuff when I was preparing to get my Rx 8 running again, but after learning that I didn’t have the larger stroke of the Mexican version (qmb-a) plus not having machining tools/not willing to pay for machine work, I opted to just get plug an play parts. The money spent for a extra 20+ mph was not worth it, anything over 60+ on these machines and especially these Chinese frames is too sketchy for my liking. Have you considered a single ring high end aluminum bore from Stage-6 or Polini I believe even Athena makes one too. It will work with stock stroke size crank that will fit in your case.
Post by 2smokeruck on Apr 18, 2019 0:06:35 GMT -5
Safe to say op was way in over his head.
