Post by motoxracer98 on Aug 16, 2017 23:56:07 GMT -5
Im having trouble finding a liquid cooled setup for my strada rx8 qmb40 maybe im searching wrong i dont know i keept finding plenty on the aerox and piaggio but nothing for my bike only thing i can find is the the standard cylinder kits stage 6 sport pro etc . Are their any Good ones out there besides the no name kit that scrappydawgscooters sells(the only one ive found) im trying to build a good 15 hp or more setup
Post by spaz12 on Aug 17, 2017 0:14:58 GMT -5
You have a Minarelli style motor so you can use an Aerox cylinder. They don't show it on your specific scoot because it's an air cooled motor. Of course you will have to make up your own cooling system, but you probably know that.
Post by gsx600racer on Aug 17, 2017 0:18:05 GMT -5
The 1PE40QMB is a minarelli clone, parts should be pretty easy to find. Polini, Malossi, Airsal, Stage 6, Naraku. Just a few brands that make goodies for this engine. You cam look here, and loose your mind making a decision.(and go broke too)
Post by motoxracer98 on Aug 17, 2017 3:57:33 GMT -5
You have a Minarelli style motor so you can use an Aerox cylinder. They don't show it on your specific scoot because it's an air cooled motor. Of course you will have to make up your own cooling system, but you probably know that. Ok awesome this info really helps. So when i order my parts i just order them for a aerox are their any other popular engines out there that are liquid cooled from the facrtory but the same as mine
Post by 190mech on Aug 17, 2017 5:34:40 GMT -5
Make sure you get the proper piston pin size..
Post by spaz12 on Aug 17, 2017 22:01:00 GMT -5
You have a Minarelli style motor so you can use an Aerox cylinder. They don't show it on your specific scoot because it's an air cooled motor. Of course you will have to make up your own cooling system, but you probably know that. Ok awesome this info really helps. So when i order my parts i just order them for a aerox are their any other popular engines out there that are liquid cooled from the facrtory but the same as mine Let me clear up that statement a bit... Cylinders and cranks will fit. Intakes are the same too, I believe. The crank driven water pumps are hard to fit because the longer studs needed between flywheel and pump are hard to find. The Aerox uses shorter studs then clones and even the Zuma motor. They leak anyway so you're better off getting an electric pump. I doubt any of the Aerox final drive gears will fit your motor. +1 on what 190mech said about piston pin size. Although I just assumed that you were getting a new crank as well. I have no experience with clone motors so I have no idea if there are any that are factory water cooled.
Post by motoxracer98 on Aug 20, 2017 13:11:56 GMT -5
This is the kit my buddy found for me i assume this will work ? Malossi MHR 90CC Malossi MHR 85mm crank For $330 new
Post by 190mech on Aug 20, 2017 15:23:43 GMT -5
Crankcase will need machine work to fit those parts unless youve got the big cases already..
Post by motoxracer98 on Aug 20, 2017 17:28:58 GMT -5
Yes i knew about that but it does fit.. Is there anyone using this same setup on here i could use some info on carb size and everything else i may need i think ive found some radiators that'll work
Post by ryan_ott on Aug 20, 2017 19:41:12 GMT -5
28mm Keihin PWK min, inner rotor iggy, electric water pump (Toyota Prius), what pipe are you planning on running?
Post by spaz12 on Aug 21, 2017 21:46:09 GMT -5
I mentioned in our messages that MHR 90's that I know of need the crazy expensive 42.3mm stroke, 90mm rod and 13mm piston pin. The two 90's that I know of are the older cylinder with single piece head (hard to find) and the new cylinder with two piece anodized head. They both use the same crank. Unless there is another MHR 90 that I don't know about that uses an 85mm rod?? Newer cylinder: scootertuning.ca/en/liquid-conversion/17089-cylinder-kit-malossi-mhr-team-testa-rossa-90cc.htmlOlder cylinder: Looked at maxiscoot, scooter attack, scoot-tuning and scootertuning and couldn't find one, but I'm sure there are a few still out there.
Post by motoxracer98 on Aug 22, 2017 18:51:29 GMT -5
28mm Keihin PWK min, inner rotor iggy, electric water pump (Toyota Prius), what pipe are you planning on running? I dont know yet buddy im trying to figure all that out what do you guys recommend? i have a brand new stage 6 pro replica here ive never uses but i guess that wont work for what im trying to do will it .. As for the kit i thought i had found the right kit but rhe guy said now he doesnt even have anymore of them so thats out of the question .. Hes trying to sell me a malossi testa rossa kit and a stroker crank for $589 he claims it will put me about 30 hp i dont really need all that though guys that kit is too much trouble from what i hear ? i dont need something im going to have to rebuild every week i plan on putting about 75 miles on it every week i want something fast but reliable it doesnt have to be the baddest thing out there ... Anyone please point me in the right direction id like to keep the cylinder kit and crank under $500
Post by niz76 on Aug 22, 2017 19:55:42 GMT -5
Don't forget you'll need a pipe too.. if you're looking in the Hyper Race category you'll also need an upgraded ignition, radiators and a water pump, tach, temp gauge etc... it adds up. A decent air cooled 70cc setup can get you into the (true) 60mph range- plus you won't need to machine out your cases for the larger 90cc+ stuff....
EDIT: Sorry, I see you're looking to go liquid cooled. That opens up a lot of options. Are you looking to go to the 90cc stuff (machine the cases out for larger components) or stay in the 70cc category?
Post by ryan_ott on Aug 22, 2017 20:26:25 GMT -5
If your looking at the hyper race stuff you can expect to spend $1000 easy on all the components (cylinder, crank, bearings, seals, intake, reeds, carb, iggy, pipe, radiators, rad hose, gauges, jets for tuning, properly setup cvt, etc.) This isn't to scare you away from the higher end stuff, everyone loves speed. Just make sure your prepared.
Post by ryan_ott on Aug 23, 2017 10:24:51 GMT -5
Another thing worthwhile updating would be getting the primary and machined cover so you can run a 3 bearing support. Well needed I think. Brent has links in his build thread.
