Post by gsx600racer on Nov 6, 2017 1:02:17 GMT -5
What is the difference between gy6 and 140qmb? GY6 has a timing chain & camshaft(4 stroke), 140qmb does not(2 stroke).
Post by stancejontland on Nov 6, 2017 23:42:17 GMT -5
will me getting that exhaust in that link mess up my scoot? i have the 140 but it says its for gy6 but they look almost exactly the same my muffler just looks longer than the one in the link.
Post by 90GTVert on Nov 7, 2017 17:07:03 GMT -5
As I've said, it should work fine.
Post by repherence2 on Nov 18, 2017 17:20:17 GMT -5
Im from Gettysburg pa. But i was out messing with the scoot today and got it to run but it only wants to idle with the idle screw alllll the way in can't get it to idle any other way and it runs better with the air screw almost the whole way out. And it idles around 1500 with the screw all the way in. Idle screw "all the way in" and air/fuel screw almost the whole way out... that doesn't sound proper. --Does your carb have an auto enricher (electric choke)? --Did you let the engine warm up before you started adjusting air/fuel and idle screws? Assuming that you didn't change any parts on the intake/carb side, I think you should let the bike warm up and then retune the screws. Your description makes it seem like your pilot jet is not the proper size. However, if you didn't change any parts, aside from the exhaust, I'm pretty sure it's not a pilot jet issue. --Are you running a fuel filter?
Post by stancejontland on Nov 28, 2017 23:02:05 GMT -5
I just ordered a new exhaust pipe and gunna try that when i get it stay tuned everyone ill need your help!!
