Post by Happypancake! on Jan 6, 2018 11:22:16 GMT -5
Post by moofus02 on Jan 6, 2018 11:33:25 GMT -5
Sweet deal. Must be an 08 or 11 being white. Boatparts.net. ? Think that's where I called for mine. New panels are real cheep. I had to actually call and have them search because I couldn't find white in 08. They found it listed as 2011 the other year they used that color. I think every piece of plastic on it would come out to less than 200 bucks shipped. Good bikes and they run, handle and stop well. If you can't hear the exhaust note go soft as it hits the Rev limiter the fuel pump is probably week. With a new 30 dollar ebay pump mine will bury the speedo and lay against the Rev limiter with dad at 5 foot 7 and 240lbs on it. Should gps at about 40 to 41mph stock
Post by Happypancake! on Jan 6, 2018 11:38:37 GMT -5
Yeah a saw plastic are much less expensive that the Honda stuff. You have a link to the pump ? Does anyone make an aftermarket unlimited CDI for it?
Post by moofus02 on Jan 6, 2018 11:56:41 GMT -5
I did an eBay search when I needed it. They are cheep. The fuel injected vino,Zuma and c3 use the same pump. Easy to change. You don't want an unlimited cdi. The only one I know of is only good for another 250rpm. Yamaha had crank issues with the 07 c3's and I'm guessing the cut the rpm back slightly to cure it. They make enough power to lay on the limiter. My opinion is up gears, cvt tune (they really have heavy rollers stock, the motor doesn't wake up until the cvt is maxed out)and stiffer clutch springs. I don't know how long the belt is in these but I was considering an over range of I could get the right belt to make it work
Post by Happypancake! on Jan 6, 2018 12:27:33 GMT -5
Thanks. CDI is always the last mod in the tune. Just looking to parallel the mods on my other scoots.
Post by pinkscoot on Jan 6, 2018 13:18:17 GMT -5
C3's are great scoots. I have a friend that has one as a daily rider and it never lets her down.I almost picked one up but could only afford the BV250 the guy was selling not both. I do always have an eye out though.
Post by benji on Jan 6, 2018 14:10:59 GMT -5
I've gotta vino 4t motor w a bad crank if you need oem parts. Just sitting around haha.
Post by oldgeek on Jan 6, 2018 14:28:29 GMT -5
Awesome find! I would take one for that kind of deal.
Post by moofus02 on Jan 6, 2018 15:00:54 GMT -5
That's the other thing about them 2t swap is easy lol
Post by benji on Jan 6, 2018 19:16:56 GMT -5
That's the other thing about them 2t swap is easy lol yep that's why I got an extra vino 4t motor laying around haha.
Post by Happypancake! on Jan 7, 2018 15:40:42 GMT -5
OK. Pulled ok that custom front cover assuming I'd find a bird's nest of wires but it looks like the PO only cut the headlight wires. Easy fix. I picked up a service manual from ebay. This will be fun.....
Post by ryan_ott on Jan 7, 2018 16:04:48 GMT -5
I bet you can fit a lot of beer under that seat. 🍻 Or tools...
Post by Happypancake! on Jan 7, 2018 16:05:28 GMT -5
Brand new battery!
Post by jbjhillbilly on Jan 7, 2018 16:09:51 GMT -5
Sweet find! The engine is very amenable to BBK work as well.
Post by 190mech on Jan 7, 2018 16:15:00 GMT -5
