Post by brombra on Apr 27, 2018 10:54:54 GMT -5
Ronin
Scoot Junior
Struggling to get my first scooter working!
Post by Ronin on Apr 27, 2018 12:03:42 GMT -5
+1
Post by 90GTVert on Apr 28, 2018 7:48:45 GMT -5
Post by brombra on Apr 28, 2018 8:49:45 GMT -5
Thank you for the reply! Yeah I'm not sure between the two either, it bogs when I open up the throttle from around 3/4 to full but I'm not sure if it's a rich or lean bog. I was hoping the plug would point me in the direction of either rich or lean bog but it seems not!
Post by brombra on Apr 28, 2018 10:33:43 GMT -5
Just been out for a ride on the scoot on a rainy English day and noticed it doesn't seem to be popping or tinging on deceleration? Has anyone got any ideas as what to be causing it or is this nothing to worry about?
Post by 90GTVert on Apr 28, 2018 12:36:29 GMT -5
Sometimes the easiest way to tell if you aren't sure is to cover a small portion of the airbox inlet with electrical tape. That will richen it up. If it gets better, you need more fuel. If it gets worse, you have too much fuel.
Post by brombra on Apr 28, 2018 15:56:10 GMT -5
Sometimes the easiest way to tell if you aren't sure is to cover a small portion of the airbox inlet with electrical tape. That will richen it up. If it gets better, you need more fuel. If it gets worse, you have too much fuel. Thank you for the advice, I'll do exactly that.
Post by brombra on Apr 28, 2018 16:03:36 GMT -5
Sorry to bug you again gt but do you recommend covering the snorkel on the airbox or the airbox side of the carb? Also how much of the intake do you recommend covering it by? Thank you.
Post by brombra on May 1, 2018 16:11:23 GMT -5
Post by 90GTVert on May 1, 2018 18:00:34 GMT -5
Sorry to bug you again gt but do you recommend covering the snorkel on the airbox or the airbox side of the carb? Also how much of the intake do you recommend covering it by? Thank you. Snorkel. Easy access, but more importantly you won't be sucking anything into the engine if it breaks loose. Small increments. Big changes may swing it so far the other way that you don't know where you're at. Definitely don't go covering most of it to start. 1/4 maybe?
Post by brombra on May 1, 2018 18:04:57 GMT -5
Sorry to bug you again gt but do you recommend covering the snorkel on the airbox or the airbox side of the carb? Also how much of the intake do you recommend covering it by? Thank you. Snorkel. Easy access, but more importantly you won't be sucking anything into the engine if it breaks loose. Small increments. Big changes may swing it so far the other way that you don't know where you're at. Definitely don't go covering most of it to start. 1/4 maybe? Thank you very much that's very useful! I'll try it at the weekend when I have time and will probably come crying back to this thread yet again begging for advise but oh well, it's getting there.
Post by geoffh on May 3, 2018 15:00:26 GMT -5
Hope you get it sorted,your plug looks lean to me but I,m far from an expert,I noticed it,s a BPR7HS I use a BR8HS in my Yamaha jog check your manual to make sure the plug is right for your scoot.
geoff
Post by brombra on May 3, 2018 15:03:41 GMT -5
Hope you get it sorted,your plug looks lean to me but I,m far from an expert,I noticed it,s a BPR7HS I use a BR8HS in my Yamaha jog check your manual to make sure the plug is right for your scoot. geoff Thank you, ended up ordering a Mikuni main jet from the US (I live in the UK) as I haven't got the time or patience to try and find the right dellorto jet for it. Yes it says in my manual to use a BPR7HS but I'm not really familiar on the numbering system used in spark plugs. What's the difference between a plug numbered 7 and one numbered 8? Thank you.
Post by geoffh on May 3, 2018 15:29:43 GMT -5
the number is the heat range the plug operates best at,but thats all I know.I also spotted your air filter snorkel in another thread it,s much larger than a Yamaha one I.ll put a picture up tommorow,Try blocking the snorkel off a little with duct tape an see what it does(I,m also in the UK Wigan "gods pie shop")
geoff
Post by brombra on May 3, 2018 15:35:45 GMT -5
the number is the heat range the plug operates best at,but thats all I know.I also spotted your air filter snorkel in another thread it,s much larger than a Yamaha one I.ll put a picture up tommorow,Try blocking the snorkel off a little with duct tape an see what it does(I,m also in the UK Wigan "gods pie shop") geoff Ahh that explains it thank you, so the higher the number the cooler the plug by what I've heard? Yes I think my airbox must have rediculously high air flow or something for a stock box because I seem to need massively larger jets than anyone else on a stock airbox just to get it even running. Thank you, it would be interesting to compare just how large it is compared to the yam one. I think until my jet comes I'm going to do exactly that and cover part of my snorkel just to make sure I'm not lean. Got to love the UK huh, weathers been interesting this week...
