Post by davidisthename on Sept 1, 2018 17:44:33 GMT -5
Let me explain the whole story. I picked up a 2006 Schwinn Graduate 50 last month. $200 and it had 132 miles on it, but it sat for twelve years in the original owners garage. I trailered it home and took it all apart. Drained the old gas, new tires and stems, new CVT belt, new starter motor, swapped 6 gram rollers for 5 gram sliders, oil change, transmission fluid change. While I was waiting for the sliders, I put it back together with the rollers in. It fired up on the first shot. I rode it for a couple days and did not notice any issue.
When the sliders came, I put them in (made a huge difference) and rode to work. At this point I had also adjusted the idle up about a full turn to the right. I didn’t notice the stuttering issue on that ride. At work I popped the top off of the carb to check out the pin to see if I could adjust it. I noticed that the gasket kind of peeled off. Almost like it had some glue on it from the factory. I used the same gasket when I put it back together. That’s the last thing I touched before the problem started. I did not take the carb apart at any time because it seemed to be functioning well despite sitting over a decade.
The problem is this...when I am at full acceleration. If I let off the gas quickly and then quickly apply acceleration again, the bike stutters or sputters like it is momentarily not getting enough fuel. Just a couple quick coughs and then it is fine.
I’m not sure why this is happening and would appreciate any advice!
Post by jbjhillbilly on Sept 1, 2018 18:03:52 GMT -5
You need to clean the carb.
Start by disassembling it. Keep the plastic and rubber parts separate and replace any dried or cracked pieces. Be careful not to tear the diaphragm. The float may be delicate as well.
Use carb cleaner on the body and jets. Wire bread ties (with the power stripped off) are a good size to run thru the holes and clean out whatever gunk is in there. You should be able to see light thru the jets. If you have it, shooting compressed air thru helps as well.
Reassemble and put it back on your bike. When you do, check that the rubber collar that holds the carb on doesn’t have any cracks or splits in it (make sure to check the bottom as well).
