Post by jetsteve2011 on Feb 18, 2019 12:45:17 GMT -5
What I plan on doing next is the crankshaft. I’ve ordered a PARMAKIT 43mm stroke & 12mm pin.(found on e-bay cheap) Then I’m getting the PARMAKIT 50mm piston kit. A 43mm stroke with 50mm piston is 84.43. From what I can find that’s as big as it gets for the vertical. I’ll have to do some milling to get it to fit. I will definitely need to get a bigger carb any suggestions on how big for 85cc?
