Post by jetsteve2011 on Jan 6, 2019 11:34:08 GMT -5
I added 20ml to the tank after I installed the bbk. I started thinking my can was contaminated. I then added a 32oz can of the 50:1(trufuel). I’ve probably got too much oil. I’d planned on using the injection just had read that need to add some to tank since pump is meant for 50cc not 70...is that bs? What do you recommend? I’m gonna drain tank and start fresh.
Post by jetsteve2011 on Jan 6, 2019 11:38:41 GMT -5
I’m leaving a lot out of what I’ve tried. It ran pretty decent on the trufuel just way oil rich. I then topped off with my 5gal can of 91 ethanol free. Shortly there after won’t even fire.
Post by jetsteve2011 on Jan 6, 2019 18:25:18 GMT -5
I found a leak at the base of cylinder. I’ve got to order a new gasket. Hopefully that’s what’s causing it not to rev?
Post by aeroxbud on Jan 7, 2019 11:07:05 GMT -5
Adding oil to the fuel is not a great idea. It's hard to know how much oil the pump is putting into the fuel. It just becomes a guessing game. Also if you add oil you would need to adjust the jetting. On 70 kits i have just always junked the pump and gone premix. Yes it's a bit of a pain, but you always get the correct amount of oil.
Post by jetsteve2011 on Jan 7, 2019 11:22:03 GMT -5
What is the ideal mix 50:1, 40:1 ?
Post by benji on Jan 7, 2019 14:46:38 GMT -5
What is the ideal mix 50:1, 40:1 ? ah, this question again. We've all debated this.
Post by oldgeek on Jan 7, 2019 16:19:01 GMT -5
The spark plug may need replacement also, excess oil will foul it quickly.
Post by ryan_ott on Jan 7, 2019 16:28:52 GMT -5
Everyone has their own preference... 40:1 with good quality oil will be just fine. Don’t use Walmart or outboard oil.
Post by jetsteve2011 on Jan 7, 2019 17:04:33 GMT -5
No I don’t wanna start that debate. I’ll try a 43.79:1 ratio🤔
Post by benji on Jan 7, 2019 19:52:59 GMT -5
Go full-race and do 20:1. It'll drip oil from everywhere and it'll kill bugs miles away. But it'll be well-lubed.
Post by benji on Jan 7, 2019 19:54:20 GMT -5
Don’t use Walmart or outboard oil. Shit. I've used Walmart brand outboard oil. I should probably be buying better oil haha. Currently I'm running Castrol 2t injector oil for snowmobiles.
Post by ryan_ott on Jan 7, 2019 20:00:31 GMT -5
Quick story, we needed 2T oil for the lawn equipment at the shop, boss called up NAPA to drop some off. A gallon of valvoline outboard oil. Still working the way through it. Some of the stuff was hard starting so I gave them a once over and the plugs were a pile of carbon goo. I’ve never seen that with the oil I use not to mention it smells almost like gear oil. So yeah use the good stuff.
Post by benji on Jan 7, 2019 20:02:08 GMT -5
Maybe it's not "low Ash".
What color is it? Blue? Red? Grey?
Post by ryan_ott on Jan 7, 2019 20:03:33 GMT -5
Its a blueish-black. I’ll check the bottle tomorrow. But it’s nasty stuff. Amsoil for me.
Post by aeroxbud on Jan 8, 2019 16:07:56 GMT -5
Don’t use Walmart or outboard oil. Shit. I've used Walmart brand outboard oil. I should probably be buying better oil haha. Currently I'm running Castrol 2t injector oil for snowmobiles. Just a thought, but you do know they make two stroke oil for motorcycle and scooters right?
