jer
Post by jer on Jan 18, 2019 11:41:23 GMT -5
Ya, very little voltage at the stator leads, on the CPI JP50, so I'll be replacing it. When I look for the fasteners to remove, it seems like there is body plastic in the way. Is it normal to remove plastic to service the stator? Or am I looking at this the wrong way?
Thanks
Post by gsx600racer on Jan 18, 2019 11:43:37 GMT -5
Can you post a picture ?
jer
Post by jer on Jan 19, 2019 9:48:54 GMT -5
Sure I can post a pic...I'll be going over to the scooter shop sometime today. 'sposed to get a bit of snow sometime soon and I wanna check the thermostat.
Post by ryan_ott on Jan 19, 2019 12:29:38 GMT -5
I don’t think I’ve ever had to pull body panels to get to the stator on any of my scoots. You’ll have to pull the fan cover off on a CPI should be 3 fasteners and a screw at the top connecting to the cylinder cover, remove the flywheel with a appropriate removal tool after removing the nut holding it on, then you’ll have access to the stator which is secured by 2 fasteners.
Post by lilpinny on Jan 19, 2019 12:30:37 GMT -5
maybe the engine plastics.
jer
Post by jer on Jan 19, 2019 16:00:30 GMT -5
I don’t think I’ve ever had to pull body panels to get to the stator on any of my scoots. Good, that's makes it lots easier. It's very cold here and I can visualize that plastic cracking at the slightest strain. I'm not quite into my new repair digs yet and the heat isn't worked out properly, so I don't leave it running as of yet.
Post by gsx600racer on Jan 19, 2019 16:09:42 GMT -5
The exhaust will need to come off. The foot peg bracket might be a problem. Then you should be able to remove the engine shroud to get to the fan and flywheel.
Post by ryan_ott on Jan 19, 2019 16:12:07 GMT -5
Hmmm... that passenger foot rest might be an issue. Hopefully you can get the fan cover past it because that looks like it could be a pain to remove. If some fasteners are difficult to reach you can usually pull the seat bucket out with just 4 bolts.
jer
Post by jer on Jan 21, 2019 17:04:32 GMT -5
Dagnabitt, 16°F here and the unican won't open. On the mandoor: the deadbolt is free but the knob is frozen. I know what my next investment will be.
jer
Post by jer on Jan 22, 2019 13:22:10 GMT -5
y'er a bunch of jinxes...not only did I need to remove the top plastic to get at the fan shroud, I'll need to remove the floorboard to replace it. I suppose I could have drilled some holes but that ain't kosher in my kitchen.
jer
Post by jer on Jan 25, 2019 9:33:37 GMT -5
Well, I got the stator out and I'll be darned if it doesn't pass all the bench tests for resistance and isolation. I must have loused up the measurements when it was all together with the engine running.
I'll put it back together and take the dynamic readings again...any ideas?
Post by harleyracer59 on Jan 25, 2019 15:10:14 GMT -5
inspect and clean all connectors associated with that circuit, maybe ohms check the connectors to be sure you are not loosing something because of bad plug connections? id also check your ground circuit as well. could be a poor ground hindering the charging circuit
jer
Post by jer on Jan 29, 2019 17:24:52 GMT -5
inspect and clean all connector That must've been it. When I put it back together, I got much different readings.
Post by FrankenMech on Jan 29, 2019 17:33:43 GMT -5
Scoot connectors are cheap crap. The crimp connections to the wires can fail. The connector blades often oxidize and connections are lost. Many are gold plated but the gold plating is very poor quality.
jer
Post by jer on Jan 30, 2019 16:31:44 GMT -5
The crimp connections to the wires can fail. Wow, I didn't think of the crimp when you called out the connections. I was only concentrating on the stake of the M and F spades. I guess a resistance test of the wire from one spade to the other. I have a very nice insulation piercing probe, but I'm not so keen to leave poke-holes unless it is unavoidable.
Anyway, I'm in a holding pattern with this Arctic Blast, fixing furnaces, jump starts, pulling stuck vehicles from the snow, and all the other emergencies that go along with it...oh yeah, and getting my mom's groceries so she doesn't need to brave the wind-chill.
