Post by snaker on Mar 12, 2019 19:32:26 GMT -5
Dang I should have added a box for a meter self test reading (touching the test leads together). Not usually a big deal but when your looking at very low ohm readings it makes a difference. The .4 ohm your seeing between blk - plate reading could very well be your meter error. You can subtract the meter error from all of the values. Ex: .4 ohm reading minus .4 ohm meter error = 0 ohms.
The blk - plate chassis reading indicates that blk is ground, the equivalent of green on most GY6. And since the blk wire and plate have no ohms to the other three wires I would say that the blk (ground) is only for the AC ignition power coil and the ignition trigger circuits.
The other three wires of the 4 pin connector would appear to be the legs of a 3 phase lighting coil as mentioned. A 3 phase magneto would usually have 3 yellow wires instead of your 3 non-black colors.
It would nice to see that .6 of the wht and yel/rd be closer to the 1.2/1.3 of the other legs. If a possible .4 ohm meter error was subtracted you would have .2 ohms. That's getting pretty low and could indicate a shorted leg.
jer
Post by jer on Mar 14, 2019 9:08:15 GMT -5
Well, don't despair, my friend. My meter is a professional grade meter, and the leads are high quality too. I always touch the leads together and it read zero when I took the readings you asked for.
I should tell you that I can start the bike and have rode it a half-dozen times for many miles. The problem is it won't power the lights and gauges, or charge the battery. I have ~9.6vDC at the battery now that I have changed the Reg/Rec. That's almost 2/3 of charging voltage. Anyway, I'd still like to be able to match up another stator. I don't mind changing the connectors if that's all it needs.
Post by snaker on Mar 14, 2019 15:41:25 GMT -5
I looked at the two links 190mech provided on page 2 of this tread. The first lists a MZ Moskito 50 as a fit. But the description and the photo show a 5 wire 7 pole stator. I would make a pretty sure bet that it is also a single phase which is the more common stator for a 50. It also has a 3 pin connector vs. your 4 pin. Lot's of mystery here. What did you replace your RR with? The Stator and RR have to be a exact match.
jer
Post by jer on Mar 14, 2019 20:37:08 GMT -5
I bought a RR from amazon. It matched right up. 2x3 6-wire plug. The wire colors matched too. When I installed it, there was no more AC voltage at the battery, so it's doing the job of the Rectifier. There isn't enuff voltage to do the Regulator job.
jer
Post by jer on Mar 16, 2019 18:15:47 GMT -5
Well, it looks like this is about as far as it goes for a problem like this. I called the NYCscooterparts guy and he couldn't be bothered...others came on like Hollywood and left me swinging after the second email. If I was in their place I would, at least, let them talk to the supplier or manufacturer because those are the next step in the process.
Does anyone know of a supplier, not retailer, for stators that might make an effort on my behalf? Thanks, /Jer/
jer
Post by jer on Mar 30, 2019 11:30:41 GMT -5
I think most of these parts suppliers just drop-ship their orders from the big boys. After explaining my problem when they say they don't have a replacement, I've been asking them for an ohm reading across the leads of another coil, and nobody wants to be bothered. I'll try a few more vendors, and if that doesn't work, I'll sell the bike as is with full disclosure: kicker w/no lights. I don't see any other end to this.
