Post by ixeking on Mar 20, 2019 13:45:41 GMT -5
I have a 2008 50cc venus and when I pulled the spark plug oil came rushing out..now this sscooter has a side mount oil tank for 2 cycle. You add the oil and it mixes it in the engine for you..any ideas why it is pouring straight thru and out the plug??
Post by brandonscoot on Mar 20, 2019 14:34:03 GMT -5
Does the scooter run still ? It sounds like your talking about oil pouring out which I would think with that much oil the bike would prevent the engine from even starting properly.
If the scooter doesn’t run I would think the problem needs to be traced more directly to the source....
Post by ryan_ott on Mar 20, 2019 15:47:54 GMT -5
Has it sat for an extended period? I think the check valve between the oil pump and carb failed letting the oil gravity feed into the lowest point, your engine.
Post by ryan_ott on Mar 20, 2019 21:02:29 GMT -5
Post by SMALL CC TEK on Mar 22, 2019 14:19:41 GMT -5
Yeah your check valve is malfunctioning or your cap is not vented or clogged . If you let one sit with a injection tank for a month or two this happens ! Turn the screw on the bottom of your float bowl drain the oil prime and attempt to start it if you get it started be ready for the TRAIN like smoke for a minute from it ! lol
