mattyslimz
Post by mattyslimz on Jun 6, 2019 18:27:31 GMT -5
The Yasuni R would work good with a street race. It's very similar to the pro replica, which was designed to work with the street race cylinder. I loved my street race. Probably one of the best cylinders for longevity and performance. Indeed, I really like it’s performance compared to the other cast 70 bores like EBay stuff, It’s been very reliable for me too.
reway
Post by reway on Jun 6, 2019 19:58:45 GMT -5
No one has the Yasuni r in stock!!!
Post by ryan_ott on Jun 6, 2019 20:05:49 GMT -5
reway
Post by reway on Jun 6, 2019 22:01:33 GMT -5
Sweet thanks
Post by benji on Jun 6, 2019 22:03:09 GMT -5
Post by ryan_ott on Jun 6, 2019 22:05:36 GMT -5
I was leaving that one up to you to post.
Post by aeroxbud on Jun 7, 2019 2:41:22 GMT -5
reway
Post by reway on Jun 18, 2019 0:51:06 GMT -5
This is the only one that worked ?
reway
Post by reway on Jun 18, 2019 0:51:25 GMT -5
It says coupon expired for me hahah
reway
Post by reway on Jun 18, 2019 0:53:01 GMT -5
You use that on road still? Hahah
Post by aeroxbud on Jun 18, 2019 4:08:10 GMT -5
You use that on road still? Hahah Oh yes 👍
reway
Post by reway on Jun 19, 2019 0:30:02 GMT -5
Okay I think I got my final order ready,
Stage6 Streetrace Stage6 Pro rep( switched from Yasuni r for price) Malossi Yellow clutch springs Malossi Yellow torque spring Dellorto 6mm main jet kit 80-98 10x14x13 10mm naraku bearing 4-5.5g stage 6 roller weights 15x12
I want to make sure 15x12 is correct size of roller for the Zuma and the Dellorto 6mm will fit in my teikei also that the 10x14x13 is correct aswell for the crank bearing. Thanks guys!
Post by benji on Jun 19, 2019 8:41:09 GMT -5
Okay I think I got my final order ready, Stage6 Streetrace Stage6 Pro rep( switched from Yasuni r for price) Malossi Yellow clutch springs Malossi Yellow torque spring Dellorto 6mm main jet kit 80-98 10x14x13 10mm naraku bearing 4-5.5g stage 6 roller weights 15x12 I want to make sure 15x12 is correct size of roller for the Zuma and the Dellorto 6mm will fit in my teikei also that the 10x14x13 is correct aswell for the crank bearing. Thanks guys! I don't think the Dellorto Jets fit the OEM carb. Buy the yasuni instead of the stage6 prorep. Why are you buying the naraku bearing, the stage6 bearing is better. Don't cheap out on important stuff like bearings and pipes. Cheap out on wear items like clutch springs and torque springs.
reway
Post by reway on Jun 19, 2019 9:43:53 GMT -5
Okay I think I got my final order ready, Stage6 Streetrace Stage6 Pro rep( switched from Yasuni r for price) Malossi Yellow clutch springs Malossi Yellow torque spring Dellorto 6mm main jet kit 80-98 10x14x13 10mm naraku bearing 4-5.5g stage 6 roller weights 15x12 I want to make sure 15x12 is correct size of roller for the Zuma and the Dellorto 6mm will fit in my teikei also that the 10x14x13 is correct aswell for the crank bearing. Thanks guys! I don't think the Dellorto Jets fit the OEM carb. Buy the yasuni instead of the stage6 prorep. Why are you buying the naraku bearing, the stage6 bearing is better. Don't cheap out on important stuff like bearings and pipes. Cheap out on wear items like clutch springs and torque springs. Yasuni R really that much better then the pro rep? I looked at a graph and yes the Yasuni R has much less of a power drop off after hitting peak power but the Stage6 pro rep actually made more peak power on the graph I looked at. I’ll see if they have the Stage6 bearing, I had the right size for the though?
reway
Post by reway on Jun 19, 2019 9:53:33 GMT -5
Also guys what size spark plugs fit in the streetrace?
