rdemilt
Post by rdemilt on Jun 9, 2019 16:04:53 GMT -5
So I'm back on the road , the fuel pump showed up Saturday, I got it installed along with the 04' ECU this morning. During the install I verified just once more that the 07' ECU was fried. Im down to 36.5 mph all while bouncing off the rev limiter, before i was hitting 39.5 with an occasional 41 mph running the 07' ECU. I have a new belt and a set of sliders on the work bench that i was planning to put in before the fuel pump failed so Ill get those items installed this week and see if i pick up any speed, all while keeping my eyes peeled for a used 07' 08' or 09' model ECU, Or as suggested hook up a CDI box.
rdemilt
Post by rdemilt on Jun 11, 2019 7:47:06 GMT -5
Yesterday I had a little free time so I installed the new belt and picked up 1 MPH, new top speed was 37.7mph. Later in the afternoon pulled the CVT and switched from 5.5 rollers to a mixture of 5.5 and 6.5 sliders, I also added a couple psi to both tires. by doing that I picked up some more speed, Im now at 41 MPH. I may do some additional CVT tuning but I think 41 mph is about all I'm going to achieve with a 15K mile motor, stock jetting, airbox, and exhaust. Ill be around to report any improvements and once again, thinks for the help !
PDub
Ann Arbor MEEEEEchigan
Post by PDub on Jun 13, 2019 12:33:04 GMT -5
Good news!
rdemilt
Post by rdemilt on Jul 15, 2019 6:52:41 GMT -5
I purchased a 2009 model ECU and switched it out over the weekend. First run I was at 43-44 MPH according to GPS So I picked up another 2 MPH. 43-44 MPH is the best any Metropolitan ran off the showroom floor so at least I'm there. I don't hear the engine bouncing off the rev limiter and I'm seeing around 8300 rpm on my tach, so maybe i can go lighter on the sliders.
Post by jbjhillbilly on Jul 15, 2019 11:30:23 GMT -5
If you haven’t downloaded the file that Happypancake!, then I highly recommend jumping into it. It really helps in the step by step process of wringing the most out the GET platform.
rdemilt
Post by rdemilt on Jul 15, 2019 14:24:25 GMT -5
If you haven’t downloaded the file that Happypancake!, then I highly recommend jumping into it. It really helps in the step by step process of wringing the most out the GET platform. I looked around but don't see what file you are referring to, id like you look at it if you can be more specific.
Post by lilpinny on Jul 15, 2019 15:07:29 GMT -5
I got a ruck 2015 ECU
Post by jbjhillbilly on Jul 16, 2019 1:52:54 GMT -5
rdemilt
Post by rdemilt on Jul 16, 2019 18:49:35 GMT -5
jbjhillbilly - Thanks for the heads up and the link, It looks like there is some good reading there. I never would have found it without your help.
Post by jbjhillbilly on Jul 17, 2019 19:04:26 GMT -5
No worries. With all the TR flotsam and jetsam in here, we should probably make it a sticky in the 4t section.
Post by lilpinny on Jul 17, 2019 23:59:37 GMT -5
They videos of all the that stuff now. It's awesome.
