Post by Kenho21 on Jul 24, 2019 18:17:37 GMT -5
That’s what I got so far. Have the degree wheel mounted as well.
The piston and head don’t look as bad as I thought they would. I haven’t taken the cylinder off yet though. I guess there’s no reason I can’t?
Post by Kenho21 on Jul 24, 2019 18:20:06 GMT -5
Also,
I put a new bearing in the CVT cover recently and when I just went to take the cover off the end of the shaft that goes into the bearing was seized in the bearing and I had to carefully pry and finagle it off. Going to order a new one along with a new front half because I broke the blade off of the current one. Anyone have a link to a good front half?
Post by Kenho21 on Jul 24, 2019 18:21:57 GMT -5
Post by Kenho21 on Jul 24, 2019 18:22:29 GMT -5
Post by jackrides on Jul 24, 2019 18:40:03 GMT -5
Never seen such a neat hole in a piston? What kind of oil and ratio?
Post by Kenho21 on Jul 24, 2019 18:41:20 GMT -5
Post by Kenho21 on Jul 24, 2019 18:43:32 GMT -5
40:1 Motul 710
It’s hard for me to believe that it was while I had it that this happened. Maybe it got worse or something.m, but I bought this non running and it has always been kinda sluggish ever since I got it running. Amazing that I’ve been able to put so many miles on it!
Post by 190mech on Jul 24, 2019 19:08:51 GMT -5
It's a non squish type head(dont use it),port layout looks good,am I seeing a crack midway between the ports???
Post by Kenho21 on Jul 24, 2019 19:20:41 GMT -5
Maybe it’s time I just get that cheapo 70cc kit and forego the Polini until I’m bored
Post by Kenho21 on Jul 24, 2019 19:22:23 GMT -5
It's a non squish type head(dont use it),port layout looks good,am I seeing a crack midway between the ports??? I might as well just get the cheap kit I was going to get in the first place if I buy a new head. There are a couple deep gouges and I see where you’re talking about with the crack, but it’s not actually cracked. The cylinder is barely salvageable at best I think... Thoughts?
Post by 190mech on Jul 24, 2019 19:35:19 GMT -5
Cylinder appears to be in good shape(from pics..)Well defined port layout,,I may have a squish style head at the shop that I can send to you($0),will check in the morning..
Post by Kenho21 on Jul 24, 2019 19:40:15 GMT -5
Oh that’d be sweet! I could PayPal or Venmo you shipping no peoblem
Post by repherence2 on Jul 24, 2019 20:29:51 GMT -5
Post by Kenho21 on Jul 24, 2019 20:44:10 GMT -5
Oh... so it all does look pretty bad haha? My lack of experience is becoming more and more obvious lol.
Post by oldgeek on Jul 24, 2019 20:47:56 GMT -5
Kenho21 It looks like the head was not centered very well on the cylinder, and it also looks like the piston was low in the cylinder at top dead center, which = big squish & low compression. You should be able to wake this thing up a good bit.
