Post by oldgeek on Aug 1, 2019 14:44:53 GMT -5
Slow down! You may or may not need a base gasket or gasket + shims. What does it look like at BDC and TDC without a gasket? IF it works out best you can just leave the gasket out and only use sealer at the base.
Also remember when adding duration, it is added twice cause the port opens sooner AND closes later.
Post by Kenho21 on Aug 1, 2019 14:59:07 GMT -5
Slow down! You may or may not need a base gasket or gasket + shims. What does it look like at BDC and TDC without a gasket? IF it works out best you can just leave the gasket out and only use sealer at the base. Also remember when adding duration, it is added twice cause the port opens sooner AND closes later. Okay, so if I wanted to increase duration by say, 3º, I would only do 1.5º change on the degree wheel?
Post by Kenho21 on Aug 1, 2019 15:41:02 GMT -5
Post by Kenho21 on Aug 1, 2019 15:50:38 GMT -5
Post by Kenho21 on Aug 1, 2019 16:05:04 GMT -5
The transfer ports look like one port is too high and one is too low...
Post by oldgeek on Aug 1, 2019 16:16:58 GMT -5
Slow down! You may or may not need a base gasket or gasket + shims. What does it look like at BDC and TDC without a gasket? IF it works out best you can just leave the gasket out and only use sealer at the base. Also remember when adding duration, it is added twice cause the port opens sooner AND closes later. Okay, so if I wanted to increase duration by say, 3º, I would only do 1.5º change on the degree wheel? Correct Others please feel free to help out!
Post by Kenho21 on Aug 1, 2019 17:23:22 GMT -5
Anyone have any input as to what to do with the transfer ports before I continue?
Post by oldgeek on Aug 1, 2019 18:14:10 GMT -5
Anyone have any input as to what to do with the transfer ports before I continue? Transfers look ok, slap a head on there and check your squish! Once you have squish where you want it, then carve the EX port the way you want it.
Post by 190mech on Aug 1, 2019 18:32:46 GMT -5
The ideal BDC setup is the piston edge is flush with the bottom of the transfer ports(for piston cooling)..Once you have that,get the durations and lets see where to go from there...
Post by Kenho21 on Aug 1, 2019 22:06:12 GMT -5
So after talking to oldgeek going to call transfers good for now and address squish. Just measured with solder and I’m getting ~1.2 - 1.3 mm. Obviously I want it closer to 0.8 or so...
Should I add another 0.5mm gasket totaling two gaskets to makeup the gap or should I use one gasket and two shims?
Post by repherence2 on Aug 1, 2019 23:33:35 GMT -5
So after talking to oldgeek going to call transfers good for now and address squish. Just measured with solder and I’m getting ~1.2 - 1.3 mm. Obviously I want it closer to 0.8 or so... Should I add another 0.5mm gasket totaling two gaskets to makeup the gap or should I use one gasket and two shims?
wouldn't adding shims or gaskets, base or head, only make the squish bigger?
it would be more like taking .5mm off the top of the jug or removing .5mm from the head flange to reduce the squish gap by .5mm
Post by Kenho21 on Aug 1, 2019 23:41:14 GMT -5
Yeah, I was just about to post that same thought lol. This is when I know it’s time to call it a night lol. Been messin with this alll day. Finish her up tomorrow hopefully. Really appreciate everyone’s help on the forum.
Post by oldgeek on Aug 2, 2019 4:27:00 GMT -5
So it sounds like using no base gasket or possibly just the thinnest shim I sent you will get your squish to around .7 -.8 and the transfers should be pretty close to being set up ideal like 190mech suggests.
Once you get your squish set, its just a matter of tweaking the EX port to whatever specs you decide on.
Post by Kenho21 on Aug 2, 2019 9:35:24 GMT -5
So it looks like my squish is ~0.8 - 1.0 mm throughout the head with no gaskets or shims. I don’t think I can really afford any shins or gaskets with a gap that big. Definitely not going to be getting the cylinder ported or anything, so I guess I’ll just have to go with what I got.
Post by 190mech on Aug 2, 2019 9:52:19 GMT -5
You can deck the top of the cylinder to get the squish right..80 grit laid on a piece of glass and a bunch of elbow grease will do it..Brent has shown the method quite a few times in his builds.
