Post by lukash616 on Sept 2, 2019 11:55:07 GMT -5
Hi Guys, new here but spent a lot of time with Scoots. Got an issue with my Piaggio NRG project that's driving me crazy. It'll start up on the button almost immediately and tick over perfectly. I can ride it around the block for about 5 mins and it feels perfect until suddenly it bogs out (can keep it alive for a little bit by feathering the throttle) but zero power and then it just cuts out. I can start it right back up again but usually have to put the choke on for some reason (manual choke lever) then it will do the same thing, but usually cut out even quicker. This weekend I replaced the fuel lines and inspected the vaccum lines, all seems to be operating correctly. Carb inspected and cleaned out. Checked reeds, all fine. I was concerned about a soft seize so I took the head off and there's no signs of scoring. I did notice some odd scorch marks on the piston head though - maybe there's a clue there? It's a Malossi Sport 70 with probably only about 30miles on it, been fighting issues ever since it went on. Any ideas would be much appreciated
Post by pinkscoot on Sept 2, 2019 12:31:47 GMT -5
Did you up jet the carb when you did the 70cc kit?
Post by lukash616 on Sept 2, 2019 12:58:45 GMT -5
Yeah played with jets for a fair while it's on a 78 currently with standard airbox and Yasuni R. Runs good while it runs
Post by lukash616 on Sept 2, 2019 14:49:52 GMT -5
Just remembered I have a video of the first time it happened!
Post by pinkscoot on Sept 2, 2019 18:03:48 GMT -5
Thats a nice scoot, I like the color. 78 sounds like it might a little small. What does your plug look like?
Post by aeroxbud on Sept 2, 2019 19:00:44 GMT -5
Sounds like it might be jettting. What was the original size jet in the carb? I would start with at least 10% bigger. I would get a jet pack. Start bigger than you think. Then work down in size.
Post by 190mech on Sept 2, 2019 19:11:41 GMT -5
Sounds like fuel starvation,,Do a fuel flow check by applying vacuum to the petcock and watching fuel flow into a canister,should be ample..Clogged fuel cap vent could cause this too...
Post by lukash616 on Sept 3, 2019 2:15:55 GMT -5
Thanks guys
Jetting is on the rich side as is, its a 53 as standard.
I've checked the fuel flow by sucking on the vaccum line and letting fuel flow into a bottle. If I put the end of fuel line lower than the petcock after applying vaccum it will just drain all day - not sure if that's supposed to happen, might have to try changing the fuel pump next.
This is the first bike I've had with a fuel tank lower than the carb, much easier to troubleshoot when the tank is up by the seat!
Post by 190mech on Sept 3, 2019 3:57:48 GMT -5
OH!Thought tank was under seat,,Yes,swap out that pump..Small engine shop has them; P/N 491922 .Also ebay etc..
Post by lukash616 on Sept 3, 2019 4:59:42 GMT -5
Alrighty, Fuel pump ordered. Also chucked a new spark plug cap in the basket as noticed the plastic is a little cracked on mine. Figure it must be one of those ¯\_(ツ)_/¯
Will keep y'all updated
Post by christopher on Sept 3, 2019 5:25:54 GMT -5
Not sure what your choke lever does, if it adds fuel and doesn't block incoming air can you leave the choke partially on to create a richer condition to see if it helps?
Post by lukash616 on Sept 5, 2019 11:27:40 GMT -5
hmm no dice... changed out the fuel pump, changed the vaccum line, changed the spark plug cap, changed fuel line from tank to pump - exactly the same.
Could it be the rings already?
Post by lukash616 on Sept 5, 2019 12:23:37 GMT -5
Hmm just dropped a couple of jet sizes and there's a big improvement... maybe it was the opposite all along, too much fuel not starvation.
Will experiment more tomorrow!
Post by lukash616 on Sept 6, 2019 12:24:42 GMT -5
Nope - gone from jet so low it wont move to jet so high it wont move, always the same. So definitely ruled out jetting I guess. Completely at a loss now.
Post by aeroxbud on Sept 6, 2019 15:38:42 GMT -5
Looks like you need to do a compression test. Probably a leak down test would be a good idea too.
