Post by 12enric on Sept 25, 2019 19:12:48 GMT -5
Hi every one the other day I bought a used Benelli Quattronove 50X, I opened the bike and I found out that the carb it has is the following one but I am not 100% sure " www.modcycles.com/mm5/merchant.mvc?Screen=PROD&Product_Code=MGMO1143_tk " my question is the following one: Which kind of jets are compatible with this carb? At the moment the bike has got a 73cc engine that I don't know which brand it is. Yesterday I took out the snorkel from the air filter, but when accelerating the bike was stalling, so I guess that I need bigger jets. thank you very much.
Post by jbjhillbilly on Sept 28, 2019 13:20:37 GMT -5
Reconnect the air filter. Without changing the jetting you’ll just have issues.
Post by 12enric on Sept 28, 2019 17:59:39 GMT -5
Hey, The air filter is connected, what I did is to take out the snorkel, the thing is that in my opinion it should be able to go without snorkel having the 75cc engine. I have a few problems with it, when I accelerate it is not a smooth acceleration, it kicks and it kind of dies when I am at 1/2 throttel, I guess that something is wrong with the carb. It might need bigger jets and rise up the nedel and a crab clean.
What do you think??
Post by geoffh on Sept 29, 2019 8:47:35 GMT -5
Enric,put the snorkel back in and get it running smoothly,then try a larger jet,the jets are sold by thread diameter and hole size 6mm x 80 e.g. check what your carb uses if your unsure just buy one a size larger ,if that fits buy a set of ten from the same vendor then tune the scoot,be very careful not to lean out the mixture as it will over heat the engine.
