Post by dandanman232 on Mar 2, 2021 21:14:30 GMT -5
My 04 zuma will run fine and then it will bog down to a stop but not cut off then I can go maybe half a mile and does it again I replaced the carburetor and went through the cvt what could be doing this I need it for work. Idk what it could be please help thanks
Post by Zino on Mar 3, 2021 7:35:44 GMT -5
Sounds Carb related . Was it running great before hand did you change anything else besides carb . what carb did you put on there ? What main jet is in there ? Do you have smaller and larger jets than that on hand ? Are you wide open does it bog ? or is this at half throttle ? Does it run best at 3/4 throttle ? What does your plug look like ?
Post by snaker on Mar 3, 2021 12:22:39 GMT -5
Like Zino said. Seems like fuel runs empty, slowly builds up, etc I would add maybe a fuel restriction: carb float, pinched fuel line, plugged filter, plugged petcock, crap in tank Also a vacuum line pinched if applicable
Post by dandanman232 on Mar 3, 2021 14:11:55 GMT -5
It started doing this all of a sudden and I thought it may be carb so I changed it with what came off it. If it was carb related it would do it the hole time not after I’ve went down the road a few times then bog to a stop and then go again could the cdi be doing it?
Post by pinkscoot on Mar 3, 2021 14:57:43 GMT -5
Sounds like something is getting hot and quitting, cools down and goes again. Sounds like any number of things. Start easy and check the plug, plug cap, wire and connections to all. Maybe coil or pick up on the fly wheel. Do some tests before you start throwing parts at it.
Post by dandanman232 on Mar 4, 2021 15:10:24 GMT -5
I checked the spark plug and my plastic cover was melted to it and has a line melted on the plastic where my cylinder is idk what could cause the line part how do I post a pic of it
Post by dandanman232 on Mar 4, 2021 15:14:40 GMT -5
Post by aeroxbud on Mar 4, 2021 16:50:24 GMT -5
That lead should be insulated. That's a very strange thing to happen.
Post by Zino on Mar 4, 2021 18:46:15 GMT -5
head gasket leak is my guess melted the plastic
Post by dandanman232 on Mar 5, 2021 11:36:05 GMT -5
So the leak down tester would tell me if the head gasket needs replacing right?
Post by aeroxbud on Mar 5, 2021 11:42:13 GMT -5
Yes it would.
Post by Zino on Mar 5, 2021 19:01:27 GMT -5
When you take the shroud off you should see on that side with the whole some blow by between the cylinder head and cylinder if it is real bad . If not sure . Take the head off and check for a blown gasket.
bluebob71
Post by bluebob71 on Mar 5, 2021 19:11:56 GMT -5
It started doing this all of a sudden and I thought it may be carb so I changed it with what came off it. If it was carb related it would do it the hole time not after I’ve went down the road a few times then bog to a stop and then go again could the cdi be doing it? im sorry but this is just not true, things move in your carb if its open slightly and more gas is getting in then ull bog. once things get moving w/e is sticking might stick after the carb is in use for a bit. does not sound electrical to me. sounds gas/air mix related. ive had ppl send me carbs that they swear up and down are full working just paid so and so x amount of dollars to have it cleaned and rebuilt blah blah blah......... guess what it was still the carb. another example is if you have a bad diaphragm it could be sealed when the pin moved up and open when its down so you wouldnt get any issues till the float started filling up.
Post by dandanman232 on Mar 5, 2021 19:15:57 GMT -5
This is not the carb no matter what carb it does it after about 5 miles so I’m starting with the plug and wire and going on that way hopefully if I get this job Monday I’m just gonna throw 500 at it and build it up alil
Post by repherence2 on Mar 6, 2021 11:48:52 GMT -5
My 04 zuma will run fine and then it will bog down to a stop but not cut off then I can go maybe half a mile and does it again I replaced the carburetor and went through the cvt what could be doing this I need it for work. Idk what it could be please help thanks Try run transparent fuel lines to help with trouble shooting. Might be a fueling issue. Transparent fuel lines helped me realize my fuel filter was faulty and bleeding air into the fuel line. In another instance, my fuel petcock (vacuum operated) was bleeding air into the fuel line as well. Without transparent fuel lines, i would have never seen the air in the fuel lines.
