Post by jareeb on Sept 29, 2014 21:30:37 GMT -5
you are sitting up higher than me. but i want stock ride height, as i drive off road sometimes. i completely built my own harness for the scooter. only have headlight and tail/brake light now. the harness works with a 139qmb gy6 as well. im doing a higher end build this winter so maybe i will need that swap info. thanks! rewelding the welds tomorrow! lets hope that the pistons comes Wednesday!!!!
Post by jareeb on Oct 1, 2014 11:25:47 GMT -5
piston came. they sent me the wrong one and wont accept that. so fucking pissed off right now! never buying from gy6store again. so im looking for a piston again! im leaving on the 9th of oct so let see if i go with a scooter or not.
Post by 90GTVert on Oct 1, 2014 12:08:53 GMT -5
PFS 169-188 is a 47mm available in 10 or 12mm. Good service with them.
Post by jareeb on Oct 2, 2014 11:19:01 GMT -5
thats who i went with. i meet them in person 2 years ago very cool guys.
Post by Clank on Oct 3, 2014 2:15:37 GMT -5
What keeps your pipe from get f-up when you do a pop-a-wheelie? :wheelie:
Post by jareeb on Oct 3, 2014 10:34:53 GMT -5
not sure yet. not sure how its gona ride. we will see
Post by jareeb on Oct 3, 2014 23:08:31 GMT -5
runs good!! so damn excited right now. welding up the frame tomorrow morning then i should be able to take it for its first test drive!! also could someone post links to replacement brake pads for the rear. and also i should get a set of pilot jets. the dell 5mm main jets work in my carb. thanks video is uploading right now. will post once its up
Post by jareeb on Oct 3, 2014 23:21:29 GMT -5
Post by 90GTVert on Oct 4, 2014 7:52:12 GMT -5
PFS #161-18 are supposed to be for these and Scrappy carries some as well. I've bought 2 sets so far, one from Scrappy and one from eBay, and neither had the grooved setup that fits on the pin like stock. Looks like the one from PFS doesn't either in the pic. If anyone knows where to get them like original (or better material) I'd be interested as well. Maybe it's not a big deal and they'd be fine, but it annoys me.
Post by jareeb on Oct 4, 2014 12:22:23 GMT -5
first test drive was a bust! started with a 98 main biggest one i have. hits a big bog. so i worked my way trying every main jet i have and the smallest i have is a 90 and thats to big. so ill have to order an 80 jet set. also what filter does everyone use?
Post by 90GTVert on Oct 4, 2014 14:23:36 GMT -5
I use the stock airbox, stock filter element, but remove the snorkel with larger than stock carbs.
Post by jareeb on Oct 6, 2014 20:55:13 GMT -5
intake is crack that is prolly my issue. anyone that lives somewhat close to me and can ship it out early tomorrow?!
Post by deanallen on Oct 6, 2014 21:45:43 GMT -5
Is a Zuma intake the same? Should be I think. I might have one and I will be in Appleton tomarrow. Let me know
Post by jareeb on Oct 6, 2014 23:00:10 GMT -5
yes they are the same.
Post by jareeb on Oct 7, 2014 11:25:57 GMT -5
best i got it to run was with an 82 (note my 80 set of jets didnt get here yet) with the choke on. i seal my intake with some rtv stuff. so hopefully i get a new intake and my jets should be here tomorrow and im think about an 85 main should do it. its already trying to pull wheelies
