Post by jhobe6678 on Oct 25, 2014 4:39:31 GMT -5
I modified my Hoca vari (heavily) to get full travel and also good takeoff.. I added spacers to the boss for good takeoff and I also filed the faces so it can close together tightly and get the belt all the way to the edge. I call it a "mini overrange" I got the idea from Brent's article in the tech section. Let's hope it holds! I seriously like the idea, I just worry about the modded parts breaking under the stress/time.
Post by jareeb on Oct 25, 2014 6:34:04 GMT -5
Ill have to think about that mod. I'd hate to break my new var.
Post by nelson on Oct 25, 2014 10:33:22 GMT -5
I would be worried about the extensions flying off and destroying things. Consider the centrifugal force when that vari is spinning at 10k. I will say it looks sturdy and "should" hold. If you had access to an aluminum welder to weld those extensions on would be best then grind down and smooth out. I need to do some vari tuning myself. I switched to the hoca vari everything else stock in trans and I have hit 65mph. I am not at the edge of the vari yet and think I can get to 70. But I also have 8:1 gear ratio!
Post by jhobe6678 on Oct 25, 2014 10:45:04 GMT -5
I would be worried about the extensions flying off and destroying things. Consider the centrifugal force when that vari is spinning at 10k. I will say it looks sturdy and "should" hold. If you had access to an aluminum welder to weld those extensions on would be best then grind down and smooth out. I need to do some vari tuning myself. I switched to the hoca vari everything else stock in trans and I have hit 65mph. I am not at the edge of the vari yet and think I can get to 70. But I also have 8:1 gear ratio! 65mph? What the hell do you have it on and what have you modified to get that speed? Oh, gear ratio...Yeah I'm way behind on that.
Post by niz76 on Oct 25, 2014 11:29:47 GMT -5
I've been running this vari on my 90cc for quite some time now... 60+ mph speeds... I've got at least 1000 miles on it by now. It holds up to daily driver abuse and lots of torque. I'd say it's passed the test.
Post by jhobe6678 on Oct 25, 2014 13:25:41 GMT -5
I've been running this vari on my 90cc for quite some time now... 60+ mph speeds... I've got at least 1000 miles on it by now. It holds up to daily driver abuse and lots of torque. I'd say it's passed the test. This place gives me serious "scooter" envy.
Post by 2TDave on Oct 25, 2014 14:02:47 GMT -5
Haha, Nelson is running a ported 90cc with a pipe and big carb. In a Jog no less. 8:1 wheelie machine!!!
Post by nelson on Oct 25, 2014 14:28:59 GMT -5
I've been running this vari on my 90cc for quite some time now... 60+ mph speeds... I've got at least 1000 miles on it by now. It holds up to daily driver abuse and lots of torque. I'd say it's passed the test. nice, if it has lasted that long then I guess no worries. I have to get my scoot back together so I can do some more tuning. I know I can hit 70, I dont know what my goal is but I do want to run the 1/8th so I would assume I need to be around 75 mph to get in the 8s
Post by nelson on Oct 25, 2014 14:30:08 GMT -5
Haha, Nelson is running a ported 90cc with a pipe and big carb. In a Jog no less. 8:1 wheelie machine!!! yes, it is little and quick! I will have some new pics up soon. I just got a lot of new stuff. Check out my thread.
Post by jhobe6678 on Oct 25, 2014 15:54:00 GMT -5
Haha, Nelson is running a ported 90cc with a pipe and big carb. In a Jog no less. 8:1 wheelie machine!!! You guys are going to make me pawn my car and then some to make this whale move.
Post by niz76 on Oct 25, 2014 16:08:29 GMT -5
Haha, Nelson is running a ported 90cc with a pipe and big carb. In a Jog no less. 8:1 wheelie machine!!! yes, it is little and quick! I will have some new pics up soon. I just got a lot of new stuff. Check out my thread. I've been following your jog thread- dang sweet scoots!
Post by jareeb on Oct 25, 2014 17:25:54 GMT -5
I've been running this vari on my 90cc for quite some time now... 60+ mph speeds... I've got at least 1000 miles on it by now. It holds up to daily driver abuse and lots of torque. I'd say it's passed the test. nice, if it has lasted that long then I guess no worries. I have to get my scoot back together so I can do some more tuning. I know I can hit 70, I dont know what my goal is but I do want to run the 1/8th so I would assume I need to be around 75 mph to get in the 8s 8.44 @ 74.** mph fastest ive gone
Post by nelson on Oct 25, 2014 19:03:52 GMT -5
nice, if it has lasted that long then I guess no worries. I have to get my scoot back together so I can do some more tuning. I know I can hit 70, I dont know what my goal is but I do want to run the 1/8th so I would assume I need to be around 75 mph to get in the 8s 8.44 @ 74.** mph fastest ive gone that is quick on a scoot, what was you 60ft ? I would assume close to 1.6? I had a car that ran low 8s and it would beat m ustangs (and ls1 on juice) it has a lot to do with traction and launch ect. I was running a 4 cylinder air cooled vw. Cant wait to do it on a scoot! Will really piss some people off!
Post by nelson on Oct 25, 2014 19:09:52 GMT -5
yes, it is little and quick! I will have some new pics up soon. I just got a lot of new stuff. Check out my thread. I've been following your jog thread- dang sweet scoots! thanks man, plan on building one then the other for my kid/ wife. The 70 is quick but just doesn't have the grunt of the 90. Big difference! I would estimate it cost $700 to build the 90 from scratch. Bought polaris case bouggt 43.5mm stroke stuffer crank and did some work to the stock cylinder. I think if people dont have parts and plan on doing a 70 build you mind as well go big. There is a huge difference in power and u can do it for about the same price. You have to fab the back brake bracket but I have seen people do that without a welder. I have a technigas pipe which isnt the best but it runs hard on the 90/24 mm carb
Post by jareeb on Oct 25, 2014 23:30:48 GMT -5
8.44 @ 74.** mph fastest ive gone that is quick on a scoot, what was you 60ft ? I would assume close to 1.6? I had a car that ran low 8s and it would beat m ustangs (and ls1 on juice) it has a lot to do with traction and launch ect. I was running a 4 cylinder air cooled vw. Cant wait to do it on a scoot! Will really piss some people off! 1.8s around there i think the best 60ft was a 1.8003 or somthing like that.
