Post by tiny on Dec 18, 2014 12:35:05 GMT -5
Good idea Teach simple is better. Just make sure you reenforce the rack as most are only rated for 5-10Lbs.
teach
Post by teach on Dec 18, 2014 13:44:11 GMT -5
Thanks guys. Not only will it work better I think it looks better too. I will be sure and reinforce it a little more, but the rack it has now is solid steel bolted directly to the frame I think it would probably hold as is. However, I don't want my trailer to pass me one day.
Post by tiny on Dec 18, 2014 13:56:38 GMT -5
it works perfectly I may have you make one for my Vino
teach
Post by teach on Dec 18, 2014 15:02:40 GMT -5
it works perfectly I may have you make one for my Vino I would be happy to, not exactly sure how to get it to Canada though. Ill post up detailed pics when its all finished up so you could have one made if you wanted.
Post by tiny on Dec 18, 2014 15:13:39 GMT -5
That would be cool. I know a welding company in my area they could do the metal work for me as I'm not too good nor do I have a welder.
Post by FrankenMech on Dec 18, 2014 18:06:57 GMT -5
Just an idea-
That curved hitch tube should probably extend from the hitch swivel all the way down to the front square tube cross-member. Otherwise you may end up with cracks at the welds.
teach
Post by teach on Dec 18, 2014 22:28:30 GMT -5
I had thought about that I was thinking I would gusset it to combat the problem.
Post by FrankenMech on Dec 19, 2014 9:40:59 GMT -5
Gussets may help, Those welds at the junction of the hitch tube and the curved front end will have a lot of force on them.
teach
Post by teach on Jan 9, 2015 14:42:34 GMT -5
Post by tiny on Jan 9, 2015 16:12:49 GMT -5
Lookin' good ol'boy
teach
Post by teach on Jan 9, 2015 17:51:26 GMT -5
Thanks I'm thinking I'll paint it black to match my scoot and do a wood floor.
Post by FrankenMech on Jan 14, 2015 23:07:53 GMT -5
It looks like you put an old science lab bench to good use for your assy table.
teach
Post by teach on Jan 17, 2015 19:46:25 GMT -5
Yeah we sure did they were originally in the schools wood shop and we needed metal working tables so I just covered them with 14ga flat (if I remember right).
teach
Post by teach on Jan 24, 2015 18:01:15 GMT -5
It's finished (except wiring). It pulls awesome. I didn't have much time today so I just pulled it around the block. I'll snap some more pictures asap.
Post by FrankenMech on Jan 24, 2015 20:03:28 GMT -5
Something is wrong. It is holding your back tire off the ground. -OOppss, or is that your center stand... Looks good.
