Post by Sitticuss on Dec 22, 2014 18:52:45 GMT -5
It doesn't have to be a hoca by any means
Post by niz76 on Dec 22, 2014 18:54:24 GMT -5
If you have to machine a 90cc case to get the 48mm crank to fit. I don't think their would be enough meat in a standard 50cc case. Yeah right? I didn't even know a 48mm like this even existed. Probably about like 190mech fitting the BWS100 crank- ran good but didn't last long!
Post by 90GTVert on Dec 22, 2014 22:59:49 GMT -5
I had a 48mm x 54mm (110cc). It's a bit of a pain IMO. None of the kits just work. 45mm will make life easier. Not saying don't do it, extra torque is nice, but the long stroke will require you to fiddle with spacers and heads and it's not good if you want higher revs. Some of them are made so they aren't much larger than a 45mm.
Post by Sitticuss on Dec 23, 2014 9:04:23 GMT -5
Post by 190mech on Dec 23, 2014 10:37:21 GMT -5
It looks nice,be good to hear if anyone has been running one for some hard miles...
Post by 2TDave on Dec 24, 2014 4:21:15 GMT -5
That's the one Oldgeek and I got. Mine is in and running but as you know it's not tuned or had any real miles put in it.
Post by Sitticuss on Dec 24, 2014 9:06:30 GMT -5
That's the one Oldgeek and I got. Mine is in and running but as you know it's not tuned or had any real miles put in it. Cool I ordered it. Thanks for the aliexpress heads up. Now I just need a suitable pipe.
Post by Sitticuss on Dec 27, 2014 5:12:45 GMT -5
Ordered the crank today..
Post by Sitticuss on Jan 10, 2015 22:23:05 GMT -5
Got the crank today...Plus decals
Post by 2TDave on Jan 11, 2015 7:23:05 GMT -5
Sweet!
Post by Sitticuss on Jan 11, 2015 20:17:33 GMT -5
Got the cases split..just a little material to remove, looks very doable. Only put one of two bearings on. I didn't like the way the other spun. I only need one to mark spacing.
Post by Sitticuss on Jan 11, 2015 22:59:47 GMT -5
well the easy side is done. but looks like i found a thin spot. what was that some JB weld on the backside? Also this case seems to be way softer than my last build.
Post by 90GTVert on Jan 12, 2015 8:26:52 GMT -5
Stuffing some JB Weld in there should fix you up.
Post by Sitticuss on Jan 13, 2015 23:46:38 GMT -5
Man doesn't anybody stock long case tranny gaskets anymore....
Post by 90GTVert on Jan 14, 2015 0:34:01 GMT -5
