Post by Sitticuss on Feb 1, 2015 22:00:53 GMT -5
That sux Sitticuss. I had mine get stuck for a moment twice during install. A little panicking and quick action with the freeze spray saved my butt. the freeze spray didn't even help me. It's all good I've been lucky so far bound to hit a snag sooner or later
Post by Sitticuss on Feb 4, 2015 6:30:05 GMT -5
I ried to use the timing wheel...after an hour and a headache I don't get it...lol
Post by 190mech on Feb 4, 2015 6:53:00 GMT -5
Post by oldgeek on Feb 4, 2015 7:00:17 GMT -5
Post by 2TDave on Feb 4, 2015 7:13:43 GMT -5
I use the easy method also and still visit that thread every time I time one.
Post by Sitticuss on Feb 4, 2015 7:31:49 GMT -5
190 total exhaust port duration.....easy method
Post by Sitticuss on Feb 4, 2015 9:53:02 GMT -5
I tired brents method I came up with 220 and 190 so 205? after that I got lost or somewhere there abouts
Post by 90GTVert on Feb 4, 2015 10:51:35 GMT -5
If you don't get the wheel on perfect TDC with the method I showed you will get different readings both ways. Both methods should produce the same numbers so put more trust in the ones that you get using the method that you do with the most confidence. Most likely it's 190.
Post by jhobe6678 on Feb 6, 2015 4:53:54 GMT -5
Yeah they are short. I searched for an extension online but ended up getting it from TT. I got the extension for mine on eBay for $10 shipped I think. Can't find the link anymore though, this was a few months ago. Glad I did too, otherwise I'd be looking under my crotch for a temp.
Post by jhobe6678 on Feb 6, 2015 4:54:46 GMT -5
Damn man, this date has kept you quite busy. Good to see
Post by Sitticuss on Feb 11, 2015 11:34:34 GMT -5
So I finally took the time to count the gears
P 13/52 4 S 13/44 3.3846 F 13.53846
Post by Sitticuss on Feb 11, 2015 13:26:12 GMT -5
Looks like I could get a much lower ratio than anything pressed together already from scootertuning if I got a set that needs pressed from scrappy's?
Post by 90GTVert on Feb 11, 2015 15:11:56 GMT -5
I don't believe the stuff Scrappy sells works for these long case engines.
Post by jhobe6678 on Feb 11, 2015 15:22:01 GMT -5
I don't believe the stuff Scrappy sells works for these long case engines. If it's like mine in the VX, the only places I saw were Scootertunning.ca and some other place I forgot the name. All I know is 2TDave said don't shop there.
Post by 90GTVert on Feb 11, 2015 15:40:40 GMT -5
Yeah, pretty much you need to shop for the places that sell the big brands and carry parts for CPI... scootertuning.ca/en/107-gears...or try to find a whole set of gears out of a Triton (10.13:1).
