Post by Sitticuss on Mar 9, 2015 11:20:31 GMT -5
Sent a message to scootertuning.ca about my gear problem. They told me they didn't know how to help me. Awesome..
Post by 2TDave on Mar 9, 2015 14:55:05 GMT -5
Is this for the short atv motor?
Post by Sitticuss on Mar 9, 2015 14:55:47 GMT -5
Nope the long case 50cc
Post by Sitticuss on Mar 9, 2015 16:22:45 GMT -5
I give up...there problem solved....No crank no gears yeah I'm done...
Post by 2TDave on Mar 9, 2015 16:55:29 GMT -5
Is it possible that another intermediate shaft would work? I may have one from another long case.
Post by Sitticuss on Mar 9, 2015 17:17:32 GMT -5
I'm sure its possible. but how do I know which one to get? I could order a new CPI shaft to fit the Malossi but how do I know if the ends of the shaft will be the same size?
right now I have from end to end 10mm/19mm/14mm..I need 10mm/17mm/14mm
Post by 2TDave on Mar 9, 2015 17:49:52 GMT -5
Did you see the one at partsforscooters? Listed as 10mm 14mm and 55.4 mm overall length.
Post by Sitticuss on Mar 9, 2015 18:34:53 GMT -5
Did you see the one at partsforscooters? Listed as 10mm 14mm and 55.4 mm overall length. [ thats it but there is no way to tell if its 17mm or 19mm
Post by 190mech on Mar 9, 2015 19:22:54 GMT -5
DUDE!Dont say quit!!Ive got some spare long case gears as many others do here,Yeah they are weird,but they are out there!Can you post just what you need with dimensions on a pic??Surely this Redneck thread cant die!!
Post by Sitticuss on Mar 9, 2015 19:53:25 GMT -5
DUDE!Dont say quit!!Ive got some spare long case gears as many others do here,Yeah they are weird,but they are out there!Can you post just what you need with dimensions on a pic??Surely this Redneck thread cant die!! www.partsforscooters.com/161-195-Idle-ShaftI need one like this ^^^^^ with a 17mm O.D. so I can press the Malossi gear on.
Post by Sitticuss on Mar 9, 2015 23:29:53 GMT -5
Well after a few steady hours of work. A drill, dremel, grinding bits, sandpaper and a six inch gear puller. Sounds easy right? Yeah It totally wasn't.
Post by Sitticuss on Mar 9, 2015 23:35:33 GMT -5
Now to see if it all fits nicely in the gear box. If it doesn't fit its REDNECK RAMPAGE TIME.
Post by Sitticuss on Mar 10, 2015 2:31:32 GMT -5
The Gear box is back together. Every thing looks good so far.
primary 14/42=3 secondary 13/44=3.384645384 Final 10.15384615
Post by Sitticuss on Mar 13, 2015 1:54:56 GMT -5
Post by iwiketuddlz on Mar 13, 2015 10:58:48 GMT -5
Vedy nice me want them dare gears you got dare...I'll trade foe my 15/50s
