Post by 2strokd on Dec 21, 2009 14:59:47 GMT -5
My bad , i guess i should have read more before i spoke. It is a tuned pipe hiding in there huh... In that case try it out, im curious now. I wonder how "tuned" of a pipe you can hide like that?
Post by shiftless on Dec 21, 2009 18:14:32 GMT -5
I think it's a nice lookin pipe, ecpecially for a sleeper application ;-}
Post by Enviromoto on Dec 23, 2009 21:01:10 GMT -5
Post by 2strokd on Dec 23, 2009 21:39:15 GMT -5
Looks pretty well considering the miles and it ran on the oil injector all its life. You should be able to pry the seals out with a little screw driver? I did...
Post by shiftless on Dec 23, 2009 22:02:18 GMT -5
A socket that fits and a few taps and the seals will come right out The other pic looks like a mangled ring holdin it, is it the mount ?
Post by 90GTVert on Dec 24, 2009 6:35:33 GMT -5
I just used a seal puller to pop the seals out of mine. Be careful not to scar the cases when you pull the seals. Stick a rag under whatever you're getting leverage from if you use a puller or screwdriver.
Post by Enviromoto on Dec 26, 2009 16:29:05 GMT -5
The seals were easy some times when I dont know I find its better to stop and ask. I used a punch and they all popped out in no time. The engine is media blasted ready for powder coat.
Post by 190mech on Dec 26, 2009 18:11:36 GMT -5
Lookin Sharp!What did ya blast them with??
Post by Enviromoto on Dec 26, 2009 18:48:34 GMT -5
Walnut shells
Post by shiftless on Dec 26, 2009 19:00:27 GMT -5
Lookin good
Post by 2strokd on Dec 28, 2009 9:33:38 GMT -5
Very nice Jeremy ! What color is it gonna be?
Post by Enviromoto on Dec 28, 2009 10:28:32 GMT -5
Engine is gonna be black, going to keep the ruckus stock, and gold accents.
Post by Enviromoto on Dec 30, 2009 17:30:26 GMT -5
Back from powder coat. Ready to go in the oven. On the rack. Presto! Now just need to prep the cases, install the vacuum pump inlet, port match the case, and wait for parts.
Post by 2strokd on Dec 30, 2009 22:18:48 GMT -5
Very nice! Mind me asking what a job like that costs? Just curious, why the bigger Mikuni vacuum pump in the first place? Are the tanks low in the Ruks?
Edit- Nevermind, just noticed your going with the stock tank in the front right?
Post by Enviromoto on Dec 31, 2009 10:32:18 GMT -5
yep floormount tank, and the stock electric pump has been known to starve a 2t for fuel causing it to seize.
Well a job like that would normally be in the $200 + range because of all the taping that needed to be done. But since I taped it all myself, hung around the shop and helped them out on the production line, and paid with cash it only cost $100.
