Post by iwiketuddlz on Jan 24, 2015 6:47:38 GMT -5
Really?? Mm does it use 3 pins? Or two? And mine is none e adjustable as well.what is the od of your pully?
Post by moofus02 on Jan 24, 2015 6:57:31 GMT -5
My overrange uses 2 pins i think and it is 128? The Morini i have uses 3 and is 123 or so and stock mina is 115 I think
Post by 2TDave on Jan 24, 2015 7:00:10 GMT -5
On my 2013 OR 3 pins 2 sets of groves.
Post by 2TDave on Jan 24, 2015 7:00:45 GMT -5
I'll measure the pulley when I have the cover off.
Post by iwiketuddlz on Jan 24, 2015 7:01:33 GMT -5
Ok thanks
Post by Clank on Jan 24, 2015 7:02:08 GMT -5
Just wanted to show you guys my scoot... Is that a spoiler on the aft end of your scoot? Where did you get that?
Post by moofus02 on Jan 24, 2015 7:02:26 GMT -5
On my 2013 OR 3 pins 2 sets of groves. I've got 2 sets of groves maybe it is 3 pin haven't looked at it in a while Sent from my SPH-L720 using proboards
Post by moofus02 on Jan 24, 2015 7:03:41 GMT -5
Just wanted to show you guys my scoot... Is that a spoiler on the aft end of your scoot? Where did you get that? One of mine came with a spoiler one with a rack Sent from my SPH-L720 using proboards
Post by Clank on Jan 24, 2015 7:05:10 GMT -5
Can you order them somewhere?
Post by moofus02 on Jan 24, 2015 7:07:12 GMT -5
Can you order them somewhere? Moofus parts hoard lol Sent from my SPH-L720 using proboards
Post by iwiketuddlz on Jan 24, 2015 7:36:24 GMT -5
Yea its a solid chunk of allum. For a spoiler ,it came with the scoot,its heavy too,I use it as a grab bar to put my scoot on center stand..
Post by 90GTVert on Jan 24, 2015 8:44:21 GMT -5
On Tritons the handle/spoiler came on standard models and matched the scoot and the mostly solid rack had a fake carbon fiber finish and only came on the GT5 models. This was the case in the early/mid 2000s models. I think later models had a rack on all of them. Other brands made either of them standard. This place shows both : www.partsforchinesescooters.com/1/GMI-107_Body_panel.html
Post by iwiketuddlz on Jan 24, 2015 22:13:45 GMT -5
So went and bought another set of long cases to prep for the evo because I didn't trust my helicoil in the second set so i guess 3 times is a charm, been grinding on these new halfs for 4hrs and may be halfway done lol,dang a shitload of grinding
Post by 2TDave on Jan 24, 2015 22:52:01 GMT -5
Post pics as your doing it. That way your passing it along to the next guy.
Post by iwiketuddlz on Jan 25, 2015 9:03:17 GMT -5
I will see if moderator will post my pics thanks.oh and can anyone find a jetholder for a pwk carb?
