Post by Lucass2T on Mar 13, 2016 7:12:41 GMT -5
Jog-Mania
Mar 13, 2016 8:31:55 GMT -5
via mobile
Post by tsimi on Mar 13, 2016 8:31:55 GMT -5
Over here? None. They don't know and don't sell Yasuni here in Japan. If I buy one then I'll have to import it.
Regarding the links you posted, oh man what have they done to those poor pipes?
Post by Lucass2T on Mar 13, 2016 9:37:59 GMT -5
Over here? None. They don't know and don't sell Yasuni here in Japan. If I buy one then I'll have to import it. Regarding the links you posted, oh man what have they done to those poor pipes? I dunno but what does it matter? With a wire wheel and a can of clear coat you can make it look like new. You'll have yourself a Yasuni for a bit over 10% of the retail price. Im trying to say i can help you find one if you like. You'll find them starting at €25 like the ones in de the link up untill almost new and hardly used for about €125.
Post by tsimi on Mar 13, 2016 11:01:59 GMT -5
Lucass2TThanks for the offer, very kind. That sounds like a good idea, the wire brush thing. The pipe might be cheap but shipping will cost me a leg and an arm. My guess is the pipe weighs around 3kg maybe a bit more that makes probably something around €50. Still cheaper than a new one though. Let me replenish my budget and I'll get back to you.
Post by tsimi on Mar 13, 2016 19:13:45 GMT -5
With a wire wheel and a can of clear coat you can make it look like new. Can you use regular clear coat or must it be some high temp stuff?
Post by aeroxbud on Mar 13, 2016 19:24:22 GMT -5
You have to use the high temp stuff or it just burns off. Even high temp paint will burn off the first part of the pipe that goes to the cylinder. Just make sure Lucass2T takes both of the baffles out to save postage
Post by spaz12 on Mar 13, 2016 19:31:19 GMT -5
Mop-n-glo floor sealer. That's what 190 says works the best for a clear coat on pipes.
Jog-Mania
Mar 13, 2016 19:53:07 GMT -5
via mobile
Post by tsimi on Mar 13, 2016 19:53:07 GMT -5
Crap, it is already difficult to find normal high temp paint here. I'll check with my local bike shop to see if they know where to get such high temp clear coat. Lucass2T Can you please check once how much shipping to Japan cost? Osaka area.
Post by Lucass2T on Mar 14, 2016 1:14:57 GMT -5
I'll check it out for ya. Motip has high temp clear coat, black, gray, white and some other colors.
Post by paceneedsstides on Mar 14, 2016 22:01:25 GMT -5
I ordered a W7 needle and a 40 idle and an 88 jet just to see if I can get 2T atomizer nd bushing to work better didn't order the 40 slide maybe next time
Jog-Mania
Mar 14, 2016 22:24:47 GMT -5
via mobile
Post by tsimi on Mar 14, 2016 22:24:47 GMT -5
Be careful with the main jet. 88 might be a bit too small since you opened additional holes into the airbox.
Post by paceneedsstides on Mar 14, 2016 22:28:39 GMT -5
well I will hve from 88-112 main and 40, 42, 55, 60 idle when parts from treatland get here this week.
Post by tsimi on Mar 14, 2016 22:37:16 GMT -5
You seem to be good equipped. I currently run 38/88 and 40 slide, W7 needle. Stock airbox without snorkel. And I think my scooter doesn't get enough air at WOT, kinda like trying to breath through a straw.
No scooters are alike. Even if you would use the exact same setup on yours it might not perform well. I just know that since I put in the 40 slider with the W7 needle (2nd from top position) the scooter has very good response and power at low and mid range with the AU stuff.
Post by tsimi on Mar 16, 2016 7:26:59 GMT -5
Sorry for the bad image quality but my phone cam quality sucks big time at night or dark surroundings. Swapped the plastics today. What a PITA that was. The blue parts are not stock Yamaha and some of the holes did not align as they should some fiddling was necessary. Will take better pics tomorrow. Also swapped back the V8 pipe and previous CVT setting.
Post by spaz12 on Mar 16, 2016 12:54:33 GMT -5
Damn, that looks good and blue is one of my favorite colors. I like the red better though.
