Post by tsimi on Apr 23, 2016 21:21:15 GMT -5
Here an image of the mixture screw without the cap.
06jog
2006 Yamaha Jog
Jog-Mania
Apr 23, 2016 23:36:01 GMT -5
via mobile
Post by 06jog on Apr 23, 2016 23:36:01 GMT -5
Here an image of the mixture screw without the cap. I consider myself as being quite smart. But not realize the screw is capped off makes me think otherwise. Thank you for the reply and good advise. I was thinking that if the 80 was on the rich side I would try taking the snorkel off. Bike seems to run ok as is but I will still do a few plug chops. First with the 80 in then if it reads either rich or lean drop down or go up 5 say 75 or 85. Then order all the jets Inbetween to find best one. Then again how much air does a little 50cc need. If I bolt on a 70cc BBK when a special comes up for a Malossi sports I will take the snorkel off then to help feed the bigger displacement with the stock carb until I change to a 17.5 or 19 dellorto.
Post by tsimi on Apr 24, 2016 0:35:25 GMT -5
Sorry forgot that you are still at 50cc. Then leave the snorkel in until you go 70cc
Post by tsimi on Apr 24, 2016 6:16:30 GMT -5
Very busy today. To my surprise the crank seals arrived today, on Sunday! That ladies and gentlemen is typical Japan. They work like crazy here even on weekends. Anyways, I installed that stupid, CVT side, crank seal and this time it went in. I first pressed it in by hand as far I could then I used the 40mm pluming pipe and the crank installer tool to push it further in past that tight spot and then used a long M8 bolt with a regular hammer to tap it in gently till that point. If it is really good or not I will see once the engine is mounted and running. I also ordered this tool here just in case I have to ever remove it in future. After the seal was installed I checked the piston ring gap. Hand honed the cylinder with 320 grid and WD40 Installed the piston (currently a 10mm with a Stage6 step down needle bearing) as soon I know that the cylinder runs I order a Malossi 12mm piston. Then I tried to find the right base gasket by checking if the ports are open and not covered. Ended up with the thinnest gasket I had 0.10mm. Then checked for squish and the best I get is 1.10mm. I was always wondering if the best squish is 0.6-0.8 then why the hell they don't produce those kits that way that you only have to bolt it on and done. Can't be that hard is it? I sure ain't grinding of anything on a nikasil cylinder or the head. I will go with that squish and see how it goes. I am sure it will perform far better then my Polini Sport. Thinking about my Sport cylinder that must have a terrible squish setting I never checked it when installing it. Finally cleaned up everything and torqued it down with 11Nm. And what would this topic be without images, so here we go.
Post by tsimi on Apr 24, 2016 19:41:46 GMT -5
I'm gonna build me a leak tester this week and make sure that the installed seal is holding.
Post by Lucass2T on Apr 25, 2016 6:09:46 GMT -5
Then checked for squish and the best I get is 1.10mm. I was always wondering if the best squish is 0.6-0.8 then why the hell they don't produce those kits that way that you only have to bolt it on and done. Can't be that hard is it? I sure ain't grinding of anything on a nikasil cylinder or the head. I will go with that squish and see how it goes. I am sure it will perform far better then my Polini Sport. Thinking about my Sport cylinder that must have a terrible squish setting I never checked it when installing it. Because not everybody checks squish when they install a BBK. When Malossi would produce these kits with real tight squish clearances ppl can ruin everything the first time they take it for a spin. And then you'll get all these complaints about crap quality and bad products and all.... But you can mill the head down around the combustion chamber so that it falls into the cylinder.
Post by tsimi on Apr 26, 2016 0:05:20 GMT -5
Can I use more than just 6psi for the leak test? I have a hard time finding a gauge that shows that low pressure. 0.2MPa and upwards is what I find mostly. That's like 29psi+
Post by spaz12 on Apr 26, 2016 0:41:52 GMT -5
You'll blow the seals out with that much
Jog-Mania
Apr 26, 2016 1:14:33 GMT -5
via mobile
Post by tsimi on Apr 26, 2016 1:14:33 GMT -5
Wait a second what about the compresion test then how many psi do you get? Wasn't it 100-180?
Post by Lucass2T on Apr 26, 2016 2:03:42 GMT -5
Wait a second what about the compresion test then how many psi do you get? Wasn't it 100-180? But thats compression on the head, in a closed space. The seals don't see that kinda pressure. Tsimi you should look for industrial suppliers. 0-1 or 0-2 bar gauges aren't that rare you know... You can even try mailing those suppliers with a real sad story that you're working on a hobby project and can't seem to find the right gauge....they might send you one for free! You can't imagine how much free stuff I got after contacting suppliers/wholesalers with such a question!
Post by tsimi on Apr 26, 2016 2:30:35 GMT -5
Lucass2T I see... thx for the quick explanation. I found gauges but they ain't that cheap, around $20 including shipping.
Post by Lucass2T on Apr 26, 2016 2:41:56 GMT -5
And what about pneumatics, hydraulics, plumbers', DIY parts suppliers? I ordered parts for my leak tester on some random plumbers' supplier website, forgot how I got to that website tho. They had all these copper and brass parts and some (cheap) gauges as well. In total i costed me something like €30 but the gauge itself was something like €5...
Post by tsimi on Apr 26, 2016 2:56:03 GMT -5
I got all the other parts together except for that gauge and something to plug the exhaust port. For the exhaust port I will create something that should not be an issue but I thought I should be able to get cheap gauges here but I tell you Japan sucks big time when it comes to DIY.
Post by spaz12 on Apr 26, 2016 3:38:20 GMT -5
When I did the compression test I got 130, which I figured was somewhat okay because when brand new the mhr rep is only making 150-155 psi. I also didn't have it torqued down because the cylinder studs I have were too short.
Post by Raizer on Apr 26, 2016 4:48:05 GMT -5
An old turbo boost gauge would probably be perfect? They go from vacuum to normally 20psi or higher. Should be able to pick up a second hand one dirt cheap from somewhere there quite easily?
