Hello
Nov 27, 2010 13:43:50 GMT -5
Post by famous on Nov 27, 2010 13:43:50 GMT -5
Hey all, I am new to this forum and new to mopeds/scooters, I was given a 49cc chinese scooter but i dont know anything about scooters im more of a car person but i LOVE the scooter is so fun. Im like 80% sure its a 4 stroke but im a noob so i dont wanna mess it up untill i get some good advice. ill be back on tonight to post a couple of pics of it because it needs some TLC and i think its a project id like to take on. My main thing is its so loud!! front brakes dont work back brakes sound like nails on a chalkboard, i have to kick start it (dead battery i think) missing a mirror and a few minor things. i hope i can get this project started even taking on a extra job to buy the parts and tools.
Hello
Nov 27, 2010 13:49:58 GMT -5
Post by famous on Nov 27, 2010 13:49:58 GMT -5
the model is Qian and its a 2006 but google doesnt have much on qian branded scooters =/
Hello
Nov 27, 2010 13:50:00 GMT -5
Post by Fox on Nov 27, 2010 13:50:00 GMT -5
:welcome:
What city are you in?
Hello
Nov 27, 2010 13:52:32 GMT -5
Post by famous on Nov 27, 2010 13:52:32 GMT -5
Thanks i live in Tampa Florida but dude i kid you not, i am the HUGEST lakers fan out here i respect the banner thumbs up
Hello
Nov 27, 2010 14:03:53 GMT -5
Post by famous on Nov 27, 2010 14:03:53 GMT -5
well after some new found research, i think its a 2 stroke which worries me because i beleive that last owner did not mix in the oil the way it should be mixed in and i filled it for the first time a few nights ago and didnt mix in oil either. ah i hope its not too bad!!!! major fail
Hello
Nov 27, 2010 15:16:59 GMT -5
Post by lshigham on Nov 27, 2010 15:16:59 GMT -5
Take a few pics, someone should be able to tell you more.
Hello
Nov 27, 2010 15:35:25 GMT -5
Post by Fox on Nov 27, 2010 15:35:25 GMT -5
The 2T scoots usually have a seperate 2 cycle oil tank and an oil injector that meters the oil into the carb. Look for an oil tank/cap under the seat.
Note: The injector may have been removed/disabled for use with pre-mixed fuel/oil but the oil tank may still be there. Don't assume that the injector is working just because the tank is there.
Hello
Nov 27, 2010 15:46:17 GMT -5
Post by famous on Nov 27, 2010 15:46:17 GMT -5
so basically it MIGHT still be mixing oil with the fuel the oil just has its own tank, ill definatly check on that when i get home, also check the oil level maybe have to add more in there
Hello
Nov 27, 2010 20:31:22 GMT -5
Post by shakerdriver on Nov 27, 2010 20:31:22 GMT -5
i replied to the other thread you posted on but here it goes again. the oil tank maybe located under the seat. if there is an inspection cover in front of the seat by your feet then it maybe there, otherwise look under the seat like fox said. good luck and
Hello
Nov 27, 2010 21:05:20 GMT -5
Post by famous on Nov 27, 2010 21:05:20 GMT -5
Ok so it's a 4 stroke =D no worries about the oil mixture pics will be up tomm when I get to work it's a SC50 engine family 6sgmc0.05gsv says here the mn octane rating should be 90 so premium next fill up?
Hello
Nov 27, 2010 21:22:37 GMT -5
Post by famous on Nov 27, 2010 21:22:37 GMT -5
I've been looking for brake pads and a battery and maybe other stuff if the prices are right but all I see in consistency online are gy6 parts and I'm doubtful if that's my engine type
Hello
Nov 27, 2010 22:14:19 GMT -5
Post by Fox on Nov 27, 2010 22:14:19 GMT -5
Post a pic of your engine/scoot. That way we can all know what you have. I have parts for 50cc 4T's.
Hello
Nov 28, 2010 14:12:33 GMT -5
Post by famous on Nov 28, 2010 14:12:33 GMT -5
Hello
Nov 28, 2010 14:14:56 GMT -5
Post by famous on Nov 28, 2010 14:14:56 GMT -5
first thing i wanna do to this thing is fix the front brakes cuz they are out completely and fix the back ones cuz they make me wanna cry when im riding and then if possible silince the muffler a little
Hello
Nov 28, 2010 15:33:56 GMT -5
Post by 90GTVert on Nov 28, 2010 15:33:56 GMT -5
That's a Baja SC50 clone (see ID plate, "MODEL : SC50"). They have the odd combination of a 139QMB (GY6 50cc) engine, paired with the CVT components of a 1E40QMB (Minarelli/Jog). The good news is that you don't have to worry about oil injection or premix. You just need to make sure the crankcase has about 800mL of oil in it. Change the oil and add that much, then get a new dipstick (goes where the rag is stuffed near the fan).
You said it's loud, so you might wanna check the header nuts and the bolts that attach the muffler to the head pipe. Make sure both gaskets are in good condition.
The front brake is disc, so try bleeding it first. Rear brake may benefit from going over the shoes and drum with emrey cloth and brake cleaner.
