Post by thatcrazyguy on Jun 12, 2015 15:16:12 GMT -5
Inflated tire, bead wasn't set right so I gotta lots of bubbles. Resettled bead and got her nice at 35 psi, tire recommends 40 but I was more surface area on the grind for my wheelies I'll sacrifice the extra speed for that. Fired her up and got a nice steady bog so no test run today, going shopping though will upjet tomorrow and get the carb tuned properly before work and ride out!!!!!
Post by thatcrazyguy on Jun 13, 2015 6:12:04 GMT -5
Went outside this morning to upjet the carb, got 3/4 screws out, decided to check my rear tire and it's flat again. So I put the 3 screws back in, grabbed my fishing pole and had a coworker pick me up lol!!!
90 engine is on hold as of right now. Gonna grab 2 new tires!!
Post by thatcrazyguy on Jun 14, 2015 17:11:36 GMT -5
Can low compression cause a very bad bog??
Post by 90GTVert on Jun 15, 2015 6:44:29 GMT -5
Possibly, but I'd think it would also be hard to start. More likely it's lean.
Post by thatcrazyguy on Jun 15, 2015 14:09:55 GMT -5
Possibly, but I'd think it would also be hard to start. More likely it's lean. It's a pain to start, maybe 10-20 kicks and have to hold throttle wide open. And it won't idle very well no matter how the idle mixture screw is set.
Post by thatcrazyguy on Jun 16, 2015 20:43:52 GMT -5
Had a fun day today, had more time than I thought I would after work and before my wife and kid got home. Dropped the engine out of the scooter, without any jack stands or above head hoist to hold the frame. That was fun, but easier than imagined. I scraped all the old gaskets off and sanded it down!! Didn't get it perfect but it did the job. I even removed the cylinder rods for a better cleanup job!! Well 3 of 4, the 4th was stuck pretty good. I reinstalled them with red thread locker. I noticed as soon as I took the bbk it smelled like straight oil and a hint of gas. Maybe I didn't mix the premix good enough and since I'm almost out of gas it's all oil. There was also a puddle of gas/oil under the crank, why's that? Tomorrow I get to remove the tire, and replace the bad valve stem. Hoping I won't have to take the tire all the way off the rim to do this!!! that is my redneck rig replacing the top end soon though lol
Post by scooterpimp on Jun 16, 2015 20:50:25 GMT -5
Red loctite? You aint never gettin those studs back out!
Post by niz76 on Jun 16, 2015 23:05:08 GMT -5
Sounds like you're gettin er done!
Post by thatcrazyguy on Jun 17, 2015 6:28:33 GMT -5
Red loctite? You aint never gettin those studs back out! That's my plan. They always come a little loose, not no more!!! Haha Thanks niz, after court today I get to play with the tire and put her all back together.
Post by thatcrazyguy on Jun 17, 2015 10:32:03 GMT -5
What's the best way to clean the outside of an engine??
Post by 90GTVert on Jun 17, 2015 12:37:14 GMT -5
A pressure washer is my favorite way, but I only do that when the engine is totally apart. Otherwise I just use a degreaser and scrub it.
Post by thatcrazyguy on Jun 17, 2015 13:54:46 GMT -5
A pressure washer is my favorite way, but I only do that when the engine is totally apart. Otherwise I just use a degreaser and scrub it. I picked up 3 wire brushes and engine degreaser. Inside scrubbing it with dawn soap water in the ac to get it halfway done than go outside in the 95 degree no cloud weather to use the degreaser!! Lol thanks Brent.
Post by thatcrazyguy on Jun 17, 2015 13:56:10 GMT -5
on my way outside. Be back when finished!!
Post by thatcrazyguy on Jun 17, 2015 14:13:41 GMT -5
Post by thatcrazyguy on Jun 17, 2015 19:11:37 GMT -5
So this is my cylinder flange with the exhaust and nut in there. Pretty redneck. painted the air box cover flat black and put 4 1/2" holes in it. how can I paint that shock without ruining the proper use of it?
