Ah ha!....... mystery solved I believe.I removed the top end yesterday, as light was failing, so just left a cloth over the piston.
This morning I had a look.
The piston has a No. 2 stamped into it, on the inlet side.
It therefore seems highly likely that the cylinder has been overbored to the next size.
This would explain the amazing condition of the cylinder, and head (for a 21 year old bike).
I simply wiped the carbon off the cylinder head, to bring it back to 'as new'.
Barrel Clean UpThe quality of the metal is very good..... quite hard...... harder than an AM6 barrel.
The ports are definitely not as good as the stock AM6 unit (which are perfectly shaped).
This Dio/Peugeot unit has misshapen ports, with bumps.
The good news is that these blemishes can be reached with a 3mm Dia diamond grinder on a Dremel type tool.
Where possible, sharp edges were removed, to help the rings.
The central inlet port interior has a bump that can also be easily relieved.
Other casting blemishes in the transfer ports can also be smoothed...... plus, of course, the casting bridges, that can be taken to a more pointed fine radius.
The exhaust port was fully cleaned, with one side flashing removed and smoothed.
I broke the glaze with carborundum paper @ 360 grit, then ran a honing tool through at slow speed, to get some even cross hatching scratches...... but nothing much, as the cylinder was already pretty good.
Flatted both the head and barrel faces...... both proved to be flat anyway.
Thoroughly washed all the grit off with paraffin, and that was it
I didn't even bother removing the piston...... it was clean.
4th Test RunI upped the main jet from 108 to 112.
Attempted to start the bike without choke....... it wouldn't.
Pulled on the choke cable, and it started immediately........ a great sign that the idle circuit is cock on.
Once warm, the motor felt much crisper....... better response.
While such thoughts are very subjective....... there can be no doubt that the motor is beginning to feel so much better.
Also, further up the throttle the bike is still accelerating.
It was beginning to rain, so I brought it back and checked the plug.
At last...... colour on the plug
I think that I can drop the main jet to 110, and take it from there.
It looks like we are beginning to get a handle on all 3 phases of the carburation
Next TestAfter establishing the throttle opening at idle, I need to mark off the throttle grip, into percentages.
I'll refit the speedo, and install a tachometer.
This will enable precise feedback to be taken from each tuning change.
The bugger is, that I've just realised that there are no gears on these bikes, making testing that much harder.
Normally you can test to max revs in each gear, and take notes..... make a change, and retest; and know that the exact same circumstance apply.
I think I'm gonna have to come up with another routine.
Perhaps other members have discovered a good methodology.
Other TasksOne thing I must do, is adjust the fork bearings..... there's too much play, and it can judder under braking.
I also really need to have a look at the rear brake.
It works fine, but......
I also need to examine the drive system, to see if I can solve the problem of delayed launch.
Either way..... good progress has been made
