The rollers arrived today!Here's what I got:
8 off 25mm D x 17mm W 19g
6 off 19mm D x 17mm W 9g
6 off 19mm D x 17mm W 16g
6 off 19mm D x 17mm W 13.8g
6 off 19mm D x 17mm W 13.6g
6 off 19mm D x 15.4mm W 7.8g
6 off 19mm D x 15.4mm W 7.5g
6 off 19mm D x 15.4mm W 6g
6 off 19mm D x 15.4mm W 8.1g
Note: I needed 16mm D x 13mm W None of them were the correct dimensions
However, I discovered that the '6 off 19mm D x 17mm W 13.6g' had a 16mm D steel insert.
So...... I placed a sharp knife on top of my original rollers, and scribed a line into the plastic of the above rollers.
With a diamond coated steel disc modded into my pedestal drill, I was able to grind the width down to 13mm.
I then removed the plastic cover, and chamfered the steel roller.
By good fortune, this created a 9g roller of 16mm D v 13mm W....... Bingo!
I repeated this to get all 6 rollers to 9g.
The cage and rollers were greased with hight temp graphite grease, and assembled.
While this was a whole lot of work that I didn't want to do....
... The fact was that the rollers that came out were 9g...... and the new, round, steel rollers, were also 9g.
So the test would be very meaningful.
Test RunPreviously the bike had drive at 5k RPM.
It now gripped at 4.6K
This in itself was a great improvement.
Further...... the general performance of the bike was so much better.
It was more responsive to the throttle.
It seemed like acceleration was better, even though that might be contrary to what would be expected.
The bike can now be ridden at a lower speed, and through the village, the revs have dropped.
It's still not perfect.
4.6K is still too high....... I'm not doing drag start races.
I want acceleration, when I'm on the move..... not from a standing start.
Clearly, by lowering the revs at launch, the power band becomes available, increasingly when it is required.
What's going on here, with the powerband?I would suggest, that with the stock exhaust/silencer unit..... decent power is available at 5k...... but it comes on song between 6k and 7k (at the moment).
This may be gearing related.
So let's say the power band is 5k to 7k.
To take maximum advantage of this powerband, I need to be launching at around 3.8k.
From current experience with the steel rollers..... with slightly heavier weights, I should be able to tootle around the village at around 4.4k...
... and because the variator lags to RPM, I will be able to whack open the throttle and be immediately in the powerband, and accelerating....... to a much higher speed.
In this way, I can then take full advantage of the PHBN carb mod..... which was effectively wasted with the previous flatted rollers.
So 9g are definitively too light for useable acceleration, and also too light for low speed running.
Hmmmmmmm!..... so what do I order?
I'm thinking 11g.
That way, if they are too heavy, I can bore them out a touch.
I just don't know how 2g will modify the performance.
However, one thing is for sure...... 9g rollers may have been fine for a 12mm Gurtner carb; but for a 16mm PHBN, I'm going nowhere - though very quickly
Here's the vid I made:
