I got the rollers fitted today 3 @ 10.8, 3 @ 10.9 - close enough, and I staggered them.
First ImpressionsIt's a completely different scoot.
It feels like a bigger engined bike...... the acceleration just keeps coming, rather than being over in a flash.
It launches with greater control..... a less frenzied launch can be had...... or a fast start, though less acceleration from standing start.
Drive is now available for slow running, and while slow running...... if the throttle is whacked open, the bike surges forward, and keeps accelerating.
Clutch GripThis now occurs at 4.4k (as compared to 4.6K).
Not a dramatic change at all.
2g additional roller weight, yet only a 200 RPM launch improvement.
I haven't tested with the cover off, but I'm guessing now, that the clutch springs have the most influence.
Trying to quantify what has happenedThe front pulley is now geared higher.
Therefore when it has drive, the bike will go faster, for a given RPM.
Hence now, I have slow running....... the engine no longer has to be screaming, just to keep the bike rolling forward.
Previously the bike was on the limit...... now the drive is positive.... it feels engaged.
The RPM change is minor, but the effect is much greater than the figures would indicate.
9g to 11g - is it the best way forward?I believe, that what we were looking for, was an earlier clutch grab.
This came, as a result of modding the front pulley movement, but we now have higher gearing, and lower RPM.
Surely the best solution would have been to have earlier clutch grip, and perhaps a minor raising of the gearing (say to 10g).
OR
No change of gearing..... but a much earlier clutch grab.
The reasoning behind this is, that if the clutch grabs earlier....... we need lower gearing, to cope with the 'less power' that is available at launch.
What we have now is higher gearing, and lower revs at launch.
It works....... it solves numerous problems....... but it is clearly not ideal (it's not tuned!).
A straightforward, earlier clutch grab, would have provided all the benefits we were looking for, without additionally raising the gearing.
An earlier clutch grab, would have created a similar effect to raising the gearing, but with improved slow running, whilst creating less adverse acceleration effect.
ConclusionIt's definitely a better bike now,
in all the core areas of rideability.
It also takes more advantage from the PHBN carb mod....... that can feed the requirement for power, as the bike continues to accelerate at speed.
However...... as Bill Clinton once said "it's the clutch springs, stupid!"
If they grabbed a little bit earlier, we could run with 10g rollers.
If they grabbed a lot earlier..... say 3.6/8K...... we could run with 9g rollers.
(Launch RPM possibility is still unclear at 9g, due to the increased gearing @ 11g)
Perhaps a new drive belt, and new clutch shoes, would deliver that...... but weaker clutch springs would be immediately on the money.
Notes:The CVT drive system certainly proves the rule....... when tuning..... changing one element, has a knock on effect on other elements.
Yet also..... changing one element, may demand other changes, if full advantage is to be gained.
The PHBN carb mod exemplifies this.The changes made, have enabled a gain to be seen from the carb mod..... but I actually think that the carb mod has somehow made the gearing mods work (just).
The real question, is whether we can isolate specific changes.... clutch grab, front gearing, rear gearing.
The problem appears to be, that stock clutch springs are too strong, in order to balance the engineering restrictions forced into place by politicians.
In effect.... with a weak engine...... a delayed RPM launch is needed to spice up the bike.
With restrictions being removed.... we don't need this artificial vivacity; we have the power to drive forward... and keep going.
Our problem is..... where to get the damned clutch springs?
Or is there another way to get it to bite a bit earlier?
I guess I need to know the spring load, and dimensions at rest.
It may then be possible to find a slightly weaker set of springs, in order to achieve launch just a bit earlier, whilst maintaining a low gearing, to give the oompfh.
