Post by redneck on Sept 14, 2015 11:11:17 GMT -5
Thanks guys does anyone knw if the hoca 52mm is any better than the scrappydogs
Post by redneck on Sept 17, 2015 15:48:15 GMT -5
well iv continued to drive the scoot as is I change my oil about every three times I ride it and I have a few issues oil no longer smells like gas but every time I change it I get a very very fine metallic metal in the oil at first I thought maybe its the cylinder walls getting scored but im not loosening any performance with the scooter if anything it has gotten faster next issue is I stated to smell oil the other day and noticed it leaking from the drain screen port so I removed it cleaned it and used a little rtv on the oring I now have no leak then went for another ride and started smelling oil again then noticed a small amount of oil covering were the dipstick goes in and noticed it burning off the exhaust as if it is building pressure in the crank case and blowing bye the dipstick and leaking out I have about 16hrs on the motor currently
Post by 90GTVert on Sept 18, 2015 11:25:10 GMT -5
I'd expect to see some particles in the oil for a while. I use a magnetic drain plug and still get some at ~4400 miles, but the worst was for the first 500-1000 miles.
Sure it's not over filled? Should only be around 600-750ml of oil to fill it.
Post by redneck on Sept 19, 2015 13:00:26 GMT -5
well that sounds promising mabey ill leave the build in for a bit longer and il have to double check but im almost positive its right at full
Post by treylaw on Sept 19, 2015 22:06:25 GMT -5
