Post by 190mech on Oct 8, 2009 20:48:59 GMT -5
I'm thinking if the torque pulley opens wider,the front has to close more to keep the belt tight and ride higher up front..Is this right? If so,then we need to make sure the weight tracks and pulley will give us that extra squeeze to keep the belt tight.Man a scoot is a real balancing act!!
Post by 90GTVert on Oct 8, 2009 21:02:58 GMT -5
Yeah. I took both of the the roughly 1mm variator washers out that I normally use to try and make sure the belt travels all the way out up front. I did a quick burnout so I could see the pulleys move and the belt goes very close to the edge of the front pulley. It's hard to tell just how far it is in the rear pulley.
Post by 2strokd on Oct 9, 2009 7:36:30 GMT -5
Why not just check it on the center stand?
Post by 90GTVert on Oct 9, 2009 8:40:41 GMT -5
My center stand doesn't get the wheel off of the ground at all so I have to do a burnout. It's more like having 2 kickstands. lol
Post by 2strokd on Oct 9, 2009 9:04:35 GMT -5
oh, i see, now that you mention it i remember from your vids. At least its not a tire shredding burnout. I pictured you roasting the hell out of your tire trying to look at the trans to see if it were shifting right lol. That would be a video lol!
Post by 2strokd on Oct 9, 2009 9:07:30 GMT -5
Yeah. I took both of the the roughly 1mm variator washers out that I normally use to try and make sure the belt travels all the way out up front. I did a quick burnout so I could see the pulleys move and the belt goes very close to the edge of the front pulley. It's hard to tell just how far it is in the rear pulley. You were running two 1mm spacers and still hitting over 55mph? Running them stacked?
Post by 90GTVert on Oct 9, 2009 9:07:32 GMT -5
I almost made a video but thought better of doing it more. I already made a little smoke and boy does that tire get sticky. It's a shame I can't launch hard enough to use the grip it's capable of.
Post by 2strokd on Oct 9, 2009 9:09:20 GMT -5
wow, we posted at the same time.
Post by 90GTVert on Oct 9, 2009 10:36:53 GMT -5
Oh, to answer the question I missed... I was running 2 spacers stacked and doing over 55. Even with 2 1mm spacers the belt won't reach the center of the front pulley though. Withthe worn belt at 15mm and 2 spacers it still didn't reach the center. I've diled off every bit of the recess for a restrictor washer and filed the vari down close to the brass sleeve inside.
Post by 190mech on Oct 11, 2009 20:00:09 GMT -5
Decided to open the CVT case today after getting the carb close, The TD would seem to 'hang' in one position,so I tore it down to find the upper 'O'-ring sheared from improper assembly causung all of the lube to puke out over many miles.Wanted to cut the slots,here is the stock; And after hogging it out; Pulley width went from 1.435" to 1.525",but the seal overhangs the clutch backplate,will fab a spacer washer to get the extra travel.. Question??Ya'll mention 'spacer washers' in the variator,where the heck do they go?My belt will not 'bottom out' on the variator pulley,how can I get it to??
Post by 2strokd on Oct 12, 2009 8:52:56 GMT -5
At the end of the drive boss, slide it on the crank right before you put the vari face on.
Post by 190mech on Oct 13, 2009 21:01:49 GMT -5
I tried to make a shim,but after measuring only needed to remove .025" so I trimmed the back flange of the seal back to the metal, them machined off the excess flange on the TD body.The 'O'ring groove is very close to the seal groove so very little of the seal groove can be cut before it gets into the 'O'ring groove,maybe .030 to.040"
Post by 2strokd on Oct 14, 2009 8:38:32 GMT -5
I just left the seal in and filed away. Filed the seal and the TD at the same time. Now the pulley doesnt hit the clutch plate when it opens all the way. I couldnt really cut anything out of my pulley grooves, looks like its already been done lol. Heres a before pic of the top. And here is the after shot. You can see that there isnt a little edge on top anymore. Not sure this did much but maybe lower the rpm,s a tad at higher speeds.
