Post by tiny on Jun 24, 2015 17:34:21 GMT -5
Nice new ride. Happy Scooting
Post by jeriksson21 on Jun 24, 2015 18:17:21 GMT -5
The Kymco has a low beam headlight out. Anyone know any good place online to buy one? Also I will be parking my scooter outside. Does anyone have any bad experiences with parking yours outside? Is it worth it to buy some sort of wheel lock?
Post by spaz12 on Jun 24, 2015 18:22:59 GMT -5
The Kymco has a low beam headlight out. Anyone know any good place online to buy one? Also I will be parking my scooter outside. Does anyone have any bad experiences with parking yours outside? Is it worth it to buy some sort of wheel lock? Yes, get one of these. Auto tracking fuckwad killer for the A holes that will try to steal it, even with a lock on it!
Post by 90GTVert on Jun 24, 2015 18:30:28 GMT -5
I think they have a 35W H4 bulb. H4 is pretty common so you can find those all over the place online. You can get them in auto parts stores, but they're probably going to be 55-65W. Higher wattage bulbs may be too hot and you may risk melting things or very worst case it could be a fire hazard. Could be a great upgrade, but beware if you try it that there's a risk.
There have been plenty of scoot thefts or attempted thefts posted here. I'd advise figuring out a way to secure the scoot. If it's outside full time, a cover is not a bad idea either.
Post by frank50e on Jun 24, 2015 18:38:42 GMT -5
My strong recommendation is at those prices I would beg borrow or steal (just my outlaw heritage) the cash and buy both.Don't know about prices in your area but those are steals,IMO
Post by jeriksson21 on Jun 24, 2015 21:10:40 GMT -5
does it flood the engine if you crank the throttle while the engine is off?? Probably a stupid question but i'm new to this and my friends keep doing that
Post by Elektrey on Jun 24, 2015 21:58:44 GMT -5
does it flood the engine if you crank the throttle while the engine is off?? Probably a stupid question but i'm new to this and my friends keep doing that no it won't, the engine has to be turning for it to suck in gas. my friends do the same thing and it bothers me too lol. I don't think people realize how fragile the throttle tube actually is.
Post by runningbuck on Jun 24, 2015 23:23:18 GMT -5
that depends their is the little burp pump on the throttle if done enough it might flood the engine
Post by Elektrey on Jun 24, 2015 23:48:51 GMT -5
that depends their is the little burp pump on the throttle if done enough it might flood the engine Burp pump? my scooter only has the throttle cable connected to the carb slide.
Post by birdman on Jun 25, 2015 0:15:12 GMT -5
Good choice!
Post by 90GTVert on Jun 25, 2015 6:54:28 GMT -5
that depends their is the little burp pump on the throttle if done enough it might flood the engine Burp pump? my scooter only has the throttle cable connected to the carb slide. Some 4Ts use an accelerator pump. It'll squirt a small amount of fuel in each time the throttle is pumped. Shouldn't be present on the 2Ts.
Post by jeriksson21 on Jun 25, 2015 12:19:21 GMT -5
Whats the best kind of Lock for a scooter? I've seen those Kryptonite chain locks but they're like 80 bucks.
Post by spaz12 on Jun 25, 2015 13:48:52 GMT -5
Get the Kryptonite if you want to keep your scoot. Not only that, but I suggest multiple locks. If you have holes big enough in your brake rotor then I highly recommend one of these: Thieves are ingenious and quick and they don't give two shits that you worked hard to buy that scoot. Another deterrent is to remove the kick starter. Not to go into detail, but they need it to steal it and if it's not there and has a good lock, they'll move onto the next poor sap.
