Post by PIG on Aug 16, 2015 22:01:57 GMT -5
I posted this up on another site, but figured I should do it here as well. I say this because, this is where I got most of my info to tackle this project, so thanks Ok, So my S6 MKI race ( the one built by Athena ) was due for rings and a hone job. Whilst pulling it apart, bigger plans started running through my head and this happened... I decided I wanted to trench/port match my cases. So some good old JB weld was used to back fill the case haves.
Post by PIG on Aug 16, 2015 22:13:29 GMT -5
Post by PIG on Aug 16, 2015 22:18:08 GMT -5
Post by iwiketuddlz on Aug 16, 2015 22:23:45 GMT -5
Very nice bro!!! ... Man I want those wheels!!!!!
Post by 90GTVert on Aug 16, 2015 22:47:45 GMT -5
Nice work. Thank you for sharing.
Post by 190mech on Aug 17, 2015 3:32:13 GMT -5
Good work!!
Post by PIG on Aug 17, 2015 14:54:34 GMT -5
Thanks guys.
Post by 2TDave on Aug 17, 2015 16:07:31 GMT -5
Well done!
Post by PIG on Aug 18, 2015 0:24:28 GMT -5
It's back on the streets annoying people again
Post by Lucass2T on Aug 18, 2015 0:27:42 GMT -5
soooo, when do we get a nice driving vid?
Post by PIG on Aug 18, 2015 0:57:59 GMT -5
I'll get the go pro out one of these days and post a video. I'm working out some tuning issues right now, but I'll get it dialed in shortly. I bought the wrong plugs and never realized it till tonight. Had a BR9HS in it and it should have been a B9HS. I use a NGK resistor cap. I also bumped the timing up a little more. I find out tomorrow if it worked.
Post by iwiketuddlz on Aug 18, 2015 11:06:31 GMT -5
Wow!!! That looks good bro!!! Nice job...... I'll take two please....!!!!
Post by derbiman on Aug 18, 2015 11:21:07 GMT -5
The R in the plug number means that it is a resistor plug meant to reduce interference in electronic equiptment such as radios. It should still work fine.
Post by PIG on Aug 18, 2015 11:31:33 GMT -5
The R in the plug number means that it is a resistor plug meant to reduce interference in electronic equiptment such as radios. It should still work fine. Yes, but you don't want a resistor in the plug and the cap. One or the other
Post by derbiman on Aug 18, 2015 11:38:06 GMT -5
My cap is a resistor cap and I run a BR8HS plug. It runs fine. Does it cause any problems with the ignition if both are resistors?
