Post by 90GTVert on Jan 13, 2010 23:11:57 GMT -5
Yeah. PartsForScooters.Com sells it. Look under 50cc for the 13mm shaft or 90cc for the 16mm shaft.
Post by 90GTVert on Jan 17, 2010 17:45:30 GMT -5
I pulled the Hoca pulley set apart to find out if it is any different than stock. I was actually kinda surprised. The clutch is pretty much like stock, just a different shoe material than my stockers have. Contra spring may be slightly stiffer than stock. The torque driver does have 3 different positions for tuning though. I figured it would be stock, but was hoping for this. ;D 1 2 3
Post by 90GTVert on Jan 25, 2010 14:08:42 GMT -5
Here's the second possibility for a BBK for T1. I think I wanna try this one. Airsal T6 47.6mm BBK What's in the box. Instructions. (Sorry, I don't have a scanner. Just took pics.) A note about oiling. I must say, the quality of this kit surprised me. I've heard people say that Airsal isn't that great so I didn't have high hopes. As I ran my fingers over the ports to see how sharp the edges were, I realized they are already chamfered. Nice.
Post by 2strokd on Jan 25, 2010 14:33:46 GMT -5
Very nice indeed ;D. I would go with that one . Nice big bridged ex. port. Should run strong.
Post by stepthrutuner on Jan 25, 2010 20:15:40 GMT -5
So T1 is about to Airsal back to life. I think the Nikasil plating likes a little more oil than iron bores. Note the recommendation for 3% synthetic oil. I did not run that heavy a mix (cheapskate ) and that could have been a reason my plating finally turned loose. I had no problems while I was using Yamalube with the injector pump for more than a year though before changing to a bigger carb and switching to premix. Good luck with the kit. Did you know that there used to be a Vento plant on the border (I guess it's no longer there) of Mexico at El Paso? So maybe hanging a Spanish part on it won't be so foreign. Also, believe it or not, there used to be a Sundiro plant here in Arkansas at Russelville NW of Little Rock. Back in '03 when I had my first scooter (139qmb Touhe) both these plants were in operation because I remember reading in Our state news paper about the one in AR and reading on the net about the one in El Paso.
Post by 90GTVert on Jan 25, 2010 20:49:33 GMT -5
I might have to have 2 fuel jugs and get used to 2 different numbers at the pump if I gotta run 32:1. I was thinking of 40:1 so I could run it on both, but I dunno. T2's iron bore is doing well at 50:1 with AMSOil.
IIRC the Vento plant was still there until just before or maybe it was just after I bought my scoot. The sales guy tried to tell me it was superior to all Chinese scooters for that reason.
Post by 190mech on Jan 25, 2010 21:04:38 GMT -5
Post us a port map of that new jug when you get a chance... THANKS!!!
Post by 90GTVert on Jan 25, 2010 21:38:11 GMT -5
I definitely will.
Post by drawkward on Jan 25, 2010 21:55:44 GMT -5
Nice kit! How much did that run you?
Post by 90GTVert on Jan 25, 2010 22:43:57 GMT -5
$99 on eBay, normally it's $179.
Post by stepthrutuner on Jan 25, 2010 23:10:38 GMT -5
Yoose iz sneaky dude. Remind me not to play chess with you. ;D
Post by 2strokd on Jan 26, 2010 5:07:00 GMT -5
I like the looks of the piston. Nice skirt on that one, get me some more pics lol. Seriously, i noticed it dosnt have a window..... its more of an open door.
Post by 90GTVert on Jan 26, 2010 7:35:23 GMT -5
I was surprised to see the piston's setup too, especially since it was pictured as a dual window in the auction and some other places.
Post by drawkward on Jan 26, 2010 10:30:49 GMT -5
$99 on eBay, normally it's $179. Oh that's the kit that was posted as a "helluva deal"? Are these better than the cast iron?
Post by shiftless on Jan 26, 2010 15:25:49 GMT -5
Nicer lookin kit Oughta make some real power
