Post by rickymalaguti on Dec 11, 2015 22:53:46 GMT -5
Post by rickymalaguti on Dec 11, 2015 23:00:45 GMT -5
Any suggestions on headlights would be awesome these just don't cut it
Post by rickymalaguti on Dec 12, 2015 14:54:53 GMT -5
Post by spaz12 on Dec 12, 2015 15:08:17 GMT -5
Your video is set to private, or something.
Post by spaz12 on Dec 12, 2015 15:12:25 GMT -5
Any suggestions on headlights would be awesome these just don't cut it You should check out Cree lights for motorcycles. I think Brent has a write up on bulbs here somewhere.
Post by rickymalaguti on Dec 12, 2015 15:12:43 GMT -5
Your video is set to private, or something. Just set it so anyone can view it sorry about that
Post by spaz12 on Dec 12, 2015 15:14:53 GMT -5
Happens all the time. It's all good.
Is that an inner rotor?
Post by rickymalaguti on Dec 12, 2015 15:17:11 GMT -5
You talking about the orange fan pulley? Which I bought only cause it was on clearance at scooter tunning ?
Post by spaz12 on Dec 12, 2015 15:19:04 GMT -5
Wait, I thought that was a water cooled motor?
Post by spaz12 on Dec 12, 2015 15:20:24 GMT -5
If it's an AC motor, you shouldn't be running it without the fan shroud.
Post by rickymalaguti on Dec 12, 2015 15:25:25 GMT -5
If it's an AC motor, you shouldn't be running it without the fan shroud. Is that why it's running a little hot ? It's air cooled motor
Post by spaz12 on Dec 12, 2015 15:29:30 GMT -5
Yeah it'll run hot without them. You're lucky it's winter time, otherwise you could have a melted motor on your hands. I would put them back on before you even think about starting it again.
Post by 90GTVert on Dec 12, 2015 15:31:13 GMT -5
Yeah, you need that shroud to direct air over the cylinder.
Very clean looking scoot.
LEDs may be effective in those housings. They didn't work out too well for me in standard headlight housings.
Post by spaz12 on Dec 12, 2015 15:37:10 GMT -5
I meant to tell you that I thought that was a cool looking scoot. All those inlets, or whatever they are, make it look tough.
Post by rickymalaguti on Dec 12, 2015 15:55:22 GMT -5
Yeah it'll run hot without them. You're lucky it's winter time, otherwise you could have a melted motor on your hands. I would put them back on before you even think about starting it again. It's suppose to be winter here in florida it's like 80's putting the cover back on Thanks for letting me know that
