Post by 90GTVert on Apr 7, 2016 10:30:22 GMT -5
Post by james49cc on Apr 7, 2016 11:21:53 GMT -5
Its just redirecting me to the homepage? Ill try search
Post by james49cc on Apr 7, 2016 14:20:09 GMT -5
Oh quick question. Apart from tuning my scoot Because of the air filters What jet should i move to? As i think it could help
Post by james49cc on Apr 10, 2016 14:20:51 GMT -5
Right i have bit the bullet and stripped it moved all to the bucket but heres the issue. Once moved the scoot wouldn't even start I re connected and still no luck finally realised that the pins was lose and reconnected then and it fires to life the mighty beast is alive but wires hanging. Anyways i tried running the wires to the handle bars and it didn't reach oh my luck and this is where im at Heres images to go with the story
Post by james49cc on Apr 10, 2016 14:22:45 GMT -5
Post by james49cc on Apr 10, 2016 14:28:22 GMT -5
Image 7 is the issue! It doesnt reach the handle bars how do i extend these wires? And what is needed as wiring im useles im just going with it and getting stuck in. Ive labeled all wires 1 + 1 so i know what goes where just for reference
Post by niz76 on Apr 10, 2016 16:02:03 GMT -5
Just cut the wires and splice in additional length. You can use butt splices but I prefer to solder and heat shrink!
Post by aeroxbud on Apr 10, 2016 16:23:17 GMT -5
Post by james49cc on Apr 13, 2016 4:25:18 GMT -5
Post by james49cc on Apr 13, 2016 6:41:35 GMT -5
This forum is the best for scoot information out their currently! Has everything a man and afew tools needs! The help is unholy! And comes in the buckets when needed. Naked build is in its final stage Just waiting on the green silicone tubes to arrive to cover the lose ends up Thankyou for all the help it was needed! 2stroked i apologies for making you draw wiring diagram for me haha!
Post by james49cc on Apr 13, 2016 13:28:45 GMT -5
Go pro fitted to observe facing traffic
Post by Deleted on Apr 13, 2016 15:39:21 GMT -5
In too deep now. Better by that solder, wire and heat shrink (3mm to 1..). If you're not really using ignition switch, maybe could use flip switch.
Post by niz76 on Apr 13, 2016 18:34:35 GMT -5
Hey lookin pretty good!
Post by james49cc on Apr 14, 2016 1:42:00 GMT -5
These handle bars are disgusting, how do i fit new ones?
Post by Raizer on Apr 14, 2016 2:28:48 GMT -5
